Hot Water Mineral Buildup - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2015, 08:10 PM   #16
mikevoth's Avatar
Rewards Points: 22
That's what I initially thought, but I only see it on the hot water side. All cold water outlets have full flow and clean screens.
mikevoth is offline   Reply With Quote
Old 12-12-2015, 08:11 PM   #17
Rewards Points: 3,208
Doesn't look like anything to do with the wh or anode rod to me. All looks good there. broken down anode rod/dip tube would appear whiteish color and littler pieces.
jmon is online now   Reply With Quote
Old 12-12-2015, 08:21 PM   #18
mikevoth's Avatar
Rewards Points: 22
So, maybe my settings are off on the softener? I have very hard water here, so maybe I should test the water again and make adjustments. ?
Old 12-12-2015, 08:31 PM   #19
That would be my guess as well. Test it and get the manual out verify settings, proper amount salt/resin, etc.
You could try bypassing the filter and softener, flush it out and see if it clears up. If it does, then you know for sure the problem lies with your your filter or softener. Just a suggestion.
Also check the filter make sure you didn't tear a hole in it or something putting it in.
Old 12-12-2015, 08:32 PM   #20
mikevoth's Avatar
Rewards Points: 22
Great suggestions! Thank you all!
The Following User Says Thank You to mikevoth For This Useful Post:
jmon (12-12-2015)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
