Hot Water Mineral Buildup - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2015, 01:34 PM   #1
mikevoth's Avatar
Rewards Points: 22
Hot water mineral buildup
I've been having an issue lately that is very annoying. All my hot water faucet screens are getting compacted with mineral deposits causing a no-fill warning for my washing machine and poor water flow from all kitchen and bathroom hot water faucets. Cold water faucets are not affected. I have a whole-house water filtration system, as well as water softener. Could incorrect hardness settings on the softener be causing this? I find it very annoying that I have clean water, yet still have crap on the hit water side. Could this be something related to my hot water heater? It's only 6-months old. At this point, if I don't get the warning beeps to stop from my washing machine, I might just throw it out the window! Any advice would be greatly appreciated! Thanks.
mikevoth is offline   Reply With Quote
Old 12-12-2015, 02:39 PM   #2
Rewards Points: 6,558
It's a little odd to have anode problems with a 6 month old heater but that may be worth investigating.
Old 12-12-2015, 02:46 PM   #3
Rewards Points: 3,486
Could be water softener affecting the wh anode rod.
When was the last time water softener was serviced/tested. Just an idea.
jmon is offline   Reply With Quote
Old 12-12-2015, 04:30 PM   #4
mikevoth's Avatar
Rewards Points: 22
I don't know what you guys mean by anode problem. So is there something in the water that is not getting removed, then being affected when heated? I just moved into the house and installed the heater, filtration system and softener the same weekend.
Old 12-12-2015, 04:32 PM   #5
mikevoth's Avatar
Rewards Points: 22
The water heater is a 50 gallon Whirlpool with automatic fire/start.
Old 12-12-2015, 04:36 PM   #6
Post a couple pictures of your set-up. Wh, filtration, and softener. Thanks.
Old 12-12-2015, 04:38 PM   #7
mikevoth's Avatar
Rewards Points: 22
Ok. Thanks. I'll do that when I get back home.
Old 12-12-2015, 04:43 PM   #8
Past history says sacrificial anode rods in water heaters have been problematic but accordingly much of that problem has been corrected according to some reports.
Google Anode Rod for details on their purpose, where on / in the heater they are located and methods of replacement.
At this point there is nothing concrete that a deteriorating rod is your problem. If you collect samples from the hot water screens that are being plugged with debris possibly someone could analyze that for a more positive yes or no.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
jmon (12-12-2015)
Old 12-12-2015, 04:49 PM   #9
Thanks Mike.
Senior brings up a good point. Also post a picture of the debris you're getting at the screens. Could be something to do with your filtration or softener and not wh. Have to investigate a little more.
Old 12-12-2015, 07:46 PM   #10
mikevoth's Avatar
Rewards Points: 22
Can't upload more than one photo at a time, so here they are…
Old 12-12-2015, 07:48 PM   #11
mikevoth's Avatar
Rewards Points: 22
#2…
Old 12-12-2015, 07:50 PM   #12
mikevoth's Avatar
Rewards Points: 22
#3…
Old 12-12-2015, 07:51 PM   #13
mikevoth's Avatar
Rewards Points: 22
#4…
Old 12-12-2015, 07:52 PM   #14
mikevoth's Avatar
Rewards Points: 22
#5…final one
Old 12-12-2015, 08:05 PM   #15
Thanks Mike for taking the time to post those pics.
It looks like resin or salt from the softener to me. Not really sure what's going on there.
There are a couple great water treatment techs that frequent this forum, they will know for sure.
By pass the water softener and see if it clears up.
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
