Hot Water Lock Out - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2016, 10:29 AM   #1
Rewards Points: 4
Hot water lock out
Have AO Smith GPSH light codes say locked out, how do I reset?
vr2016 is offline   Reply With Quote
Old 04-04-2016, 02:52 PM   #2
Rewards Points: 3,202
Re: Hot water lock out
Find out why it locked out and correct that first. Get manual and Check your error codes it usually tells you whats wrong. Flame sensor dirty, blocked air filter, exhaust issue, safety switch, etc.. Then reset it. All that info should be right in the owners manual on how to do it.
If no manual, post model number and someone will find it. Thanks.
jmon is online now   Reply With Quote
The Following 3 Users Say Thank You to jmon For This Useful Post:
oh'mike (04-04-2016), SHEPLMBR (04-05-2016), vr2016 (04-05-2016)
Old 04-05-2016, 08:44 AM   #3
Rewards Points: 4
[QUOTE=vr2016;3175409]Have AO Smith GPSH light codes say locked out, how do I reset?
Thanks- so another question if you can help much appreciated!
Lights say:
Problem--System in Lockout
Solution--1.Gas supply off or too low
2.hot surface ignitor not positioned correctly
3.low voltage
4.polarity incorrect
any suggestions--I changed the hot surface ignitor cause it wouldn't glow..
the screw lines up correctly... heater fan turns on and runs and glows for 20 seconds or so, 2-3 times before lights come on and stops....basically it never actually lights
thanks again!
Old 04-05-2016, 08:51 AM   #4
Rewards Points: 258
then try #1..gas issue...measure the gas pressure to see if there is a blockage or restriction somewhere..
woodchopper65 is offline   Reply With Quote
The Following 2 Users Say Thank You to woodchopper65 For This Useful Post:
jmon (04-05-2016), vr2016 (04-05-2016)
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
