Hot Water Leaking From Gas Control Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2016, 10:43 PM   #1
Rewards Points: 4
hot water leaking from gas control valve
Has anyone seen this before? My whirlpool hot water heater is leaking from the gas control valve. Suggestions?
bobcat1979 is offline   Reply With Quote
Old 03-04-2016, 11:00 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,940
Most likely the tank is leaking and just running down the pipes or sensors to the valve. There is no interconnection between gas and water in a properly functioning water heater.
Old 03-04-2016, 11:03 PM   #3
Rewards Points: 4
Thanks! That's what I thought. This thing is only 4 years old! Now to figure out how Home Depot will honor the warranty!
Old 03-05-2016, 04:22 AM   #4
Rewards Points: 6,652
They will not. The mfg most likely will not if it is coming from the connections, or it is where water got down the B Vent some how.
Whirlpool water heaters are junk and not worth fighting for the same one. Go to a local plumbing house or order online a A. O. Smith or the Rheem/Richmond series.
BTW, it is a Water Heater. Hot Water is what it creates.
Tags
hot water heater problems , plumbing
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 02:47 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
