Hot Water Issue In One Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-27-2016, 07:26 PM   #1
Rewards Points: 16
Hot water issue in one bathroom
I have two bathrooms upstairs, back to back. One has a shower only, the other a tub & shower, both have Delta single handle fixtures. The one with the shower only gets hot water pretty much all the time, the other has had issues last year. I called Delta to ask about parts and they told me it was warrantied forever and sent me a pair of new cartridges and springs. I replaced the parts in both showers and also put in low-flow shower heads, that seemed to fix the problem.
Recently my wife hurt her back and decided she wanted a hot bath so she turned on the tub and at first it was hot, but within a minute or so it got warm and then cold. She'd shut it off for a few minutes, turn it back on and it'd be warm at best. After about 10 minutes she'd turn it on again and it'd be hot for a minute then back to warm or cold. If I run the hot water in the other bathroom or downstairs it's hot.
I do not have a hot water heater, I have an oil fired furnace that heats water. I was thinking that maybe the tub is using hot water faster than the furnace can make it, could that be right? Or is there some other issue here? Could it be the cartridge in the faucet again?
I'm getting tired of boiling water and running it upstairs every time my wife wants a hot bath, I need to fix this.
Any suggestions?
mikelbeck is offline   Reply With Quote
Old 02-28-2016, 02:41 AM   #2
An old Tradesmen
Rewards Points: 9,248
A boiler with a tankless coil is easy to over tap.
Might want to consider an indirect, or aquastore tank.
Old 02-28-2016, 04:53 AM   #3
WhatRnsdownhill's Avatar
Rewards Points: 2,220
you can try and have the coil cleaned and see if you get more hot water, thats the cheapest fix at this point..
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
JERRYMAC (02-28-2016)
Old 03-01-2016, 08:23 PM   #4
Rewards Points: 16
Is that something I can do myself or is it a job better left to a pro? If I need a pro what should it cost (approximately)?
Old 03-01-2016, 09:08 PM   #5
shouldnt cost too much, its done with ultra sound to sorta vibrate the buildup on the outside of the coil...just google the yellow pages...
Old 03-02-2016, 03:32 AM   #6
An old Tradesmen
Here, we use a chemical to descale the coil. And pump it through the coil until its clean.
Old 03-02-2016, 06:15 AM   #7
that good for the inside, but you need ultra sound to clean the boiler side, and it also does the descaling in one process...
Old 03-02-2016, 09:35 AM   #8
Rewards Points: 16
Have you any idea what it should cost to clean both the inside & boiler side?
I'm on Long Island too, in Suffolk. Any recommendations for who can do it?
Old 03-02-2016, 02:30 PM   #9
An old Tradesmen
Must have really crappy water in your area. Never had a tankless coil coated/scaled or mucked up enough on the boiler side to have any noticeable effect on it.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (03-02-2016)
Old 03-02-2016, 03:02 PM   #10
Rewards Points: 127
It is most certainly that tankless coil in the boiler . The cleaning solutions provided by others may work ( I have no experience ) but I would start budgeting for an indirect water heater connected to your boiler or a standalone water heater. Your faucets are probably just fine .
jimn01 is offline   Reply With Quote
Old 03-02-2016, 05:28 PM   #11
yes we do, the old water mains are just flaking away, so you get a large amount of rust and iron in the water...
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
issue with hot water heat and domestic hot water, tankless coil on boiler JustinNY HVAC 6 12-06-2013 08:48 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
