Hot Water Heater Vent - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By TarheelTerp
Old 04-01-2019, 09:34 PM   #1
Rewards Points: 54
Does this water heater look like it is installed correctly? I dont see a vent hood on it. Not sure if this layout is normal? I know nothing about these things. Thanks
https://imgur.com/WOk2lGo
Hot Water Heater Vent-ba7ba8c6-7c8b-4ee8-b2e4-aecc1dc1de3c_1554172627372.jpg
mi26 is offline   Reply With Quote
Old 04-02-2019, 05:55 AM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,002
Re: Hot Water Heater Vent
The details you show here look correct enough.
Domo likes this.
TarheelTerp is online now   Reply With Quote
Old 04-02-2019, 06:08 AM   #3
Rewards Points: 54
Thanks. I don’t see a traditional vent hood on newer units that’s why I asked. How can I tell if it’s venting properly ?
Old 04-02-2019, 06:39 AM   #4
Rewards Points: 174
I think its ok.
MasterPipe is offline   Reply With Quote
Old 04-02-2019, 06:59 AM   #5
Rewards Points: 70
I dont see a vent hood on it. .....
If you mean draft hood, your picture directly centers on it. It like fine from the picture.
Cheers!
supers05 is online now   Reply With Quote
Old 04-02-2019, 01:33 PM   #6
Rewards Points: 705
Not sure about the galvanized to copper connections on the water supply
ct18 is offline   Reply With Quote
Old 04-02-2019, 03:03 PM   #7
Rewards Points: 54
Why what could go wrong with that?
Old 04-02-2019, 04:47 PM   #8
Rewards Points: 70
Nowadays you wouldn't want to mix metals like that. Back in the day it was fairly common.
Iron rusts very quickly. The galvanizing on it protects it for a while, but eventually it rusts too. The zinc becomes like an anode and protects everything else, until it's gone from inside. Today's products aren't as strong as things used to be.
Cheers!
Old 04-02-2019, 07:23 PM   #9
Rewards Points: 1,850
It's easy to check the venting. Run some hot water till wh kicks on.
You could do some low tech checks like cupping your hand sideways around hood without touching pipe, you should not feel any pushing of air coming from hood.
You could also do the match or lighter test. The airflow should draw the flame into the hood. If it sputters or goes out you could have a blockage, vent pipe not high enough or down draft/back draft issue.
Finally, make sure a carbon monoxide detector is installed on every level of the house including basement if you have one. Also install one in your utility room if that is where your wh and furnace are.
jmon is online now   Reply With Quote
Whirlpool Energy Saver Water Heater Problem Thurman Electrical 53 10-30-2018 11:08 AM
Water heater issues?!? NJdan Plumbing 1 06-04-2015 07:42 PM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
