DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Plumbing (https://www.diychatroom.com/f7/)
-   -   Hot Water Heater Vent (https://www.diychatroom.com/f7/hot-water-heater-vent-656583/)
mi26 04-01-2019 09:34 PM
1 Attachment(s)
Does this water heater look like it is installed correctly? I dont see a vent hood on it. Not sure if this layout is normal? I know nothing about these things. Thanks
https://imgur.com/WOk2lGo
TarheelTerp 04-02-2019 05:55 AM
Re: Hot Water Heater Vent
The details you show here look correct enough.
mi26 04-02-2019 06:08 AM
Thanks. I don’t see a traditional vent hood on newer units that’s why I asked. How can I tell if it’s venting properly ?
MasterPipe 04-02-2019 06:39 AM
I think its ok.
supers05 04-02-2019 06:59 AM
I dont see a vent hood on it. .....
If you mean draft hood, your picture directly centers on it. It like fine from the picture.
Cheers!
ct18 04-02-2019 01:33 PM
Not sure about the galvanized to copper connections on the water supply
mi26 04-02-2019 03:03 PM
Why what could go wrong with that?
supers05 04-02-2019 04:47 PM
Nowadays you wouldn't want to mix metals like that. Back in the day it was fairly common.
Iron rusts very quickly. The galvanizing on it protects it for a while, but eventually it rusts too. The zinc becomes like an anode and protects everything else, until it's gone from inside. Today's products aren't as strong as things used to be.
Cheers!
jmon 04-02-2019 07:23 PM
It's easy to check the venting. Run some hot water till wh kicks on.
You could do some low tech checks like cupping your hand sideways around hood without touching pipe, you should not feel any pushing of air coming from hood.
You could also do the match or lighter test. The airflow should draw the flame into the hood. If it sputters or goes out you could have a blockage, vent pipe not high enough or down draft/back draft issue.
Finally, make sure a carbon monoxide detector is installed on every level of the house including basement if you have one. Also install one in your utility room if that is where your wh and furnace are.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
