Hot Water Heater No Signs Of Life - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By supers05
Old 11-27-2018, 12:17 PM   #1
Rewards Points: 603
Hot Water Heater No Signs of Life
Smallish (30 gallon) conventional HW Heater has power, but shows no signs of life. Is there any other troubleshooting or fix that could be done, or do you just buy a new one?
Curmudgeon10 is offline   Reply With Quote
Old 11-27-2018, 01:30 PM   #2
retired framer
Rewards Points: 962
Re: Hot Water Heater No Signs of Life
The Following User Says Thank You to Nealtw For This Useful Post:
Curmudgeon10 (11-27-2018)
Old 11-27-2018, 02:16 PM   #3
Rewards Points: 799
There is power to the elements. They may need to be replaced.
ct18 is offline   Reply With Quote
Old 11-27-2018, 02:24 PM   #4
retired framer
Rewards Points: 962
If it's 5 years old I would replace it.
Old 11-27-2018, 03:25 PM   #5
Rewards Points: 603
Yes, mulling that over. It's in my separate building I use for a wood shop and gets very spotty use. Looking at some of these low priced tankless units at Lowe's/Home Depot.
Old 11-27-2018, 03:31 PM   #6
retired framer
Rewards Points: 962
The one you just put in the hot water line. Sounds like a plan if it gets little use.
Old 11-27-2018, 06:27 PM   #7
Rewards Points: 80
Do note their fairly high power requirements.
Cheers!
supers05 is offline   Reply With Quote
Old 11-27-2018, 08:58 PM   #8
retired framer
Rewards Points: 962
Cheers!
As opposed to 30 gal at temp 24/7??
Old 11-27-2018, 09:13 PM   #9
Rewards Points: 80
As in total current draw may be more then the current wiring can handle. The whole point of a tank is to spread out the load over time, so that it's not so demanding on infrastructure.
Cheers!
Old 11-27-2018, 09:19 PM   #10
retired framer
Rewards Points: 962
Cheers!
so it comes down to gal. per week, I guess.
supers05 likes this.
Old 11-27-2018, 09:29 PM   #11
Rewards Points: 80
Yes. You either heat it over an hour or 2 in a tank or over the few seconds as it passes the heater.
The instant is less wasteful, but it also requires lots of current for a very short time. As long as the OP keeps an eye out for that, they should be OK.
Cheers!
Nealtw likes this.
Old 11-29-2018, 02:26 AM   #12
Rewards Points: 202
I think you could take new.
MasterPipe is offline   Reply With Quote
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
