Hot Water Heater Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-10-2016, 04:01 PM   #16
An old Tradesmen
Rewards Points: 9,430
Originally Posted by Mstrlucky74 View Post
Non compliant chimney????
By code. chimney is not allowed to be more then 7 times the smallest appliances breech opening. So a 3" breeched/draft hooded/dilution hooded water heater. May not be connected to a flue pipe or chimney that is more then 49 sq in in cross section.
Old 02-10-2016, 06:38 PM   #17
Rewards Points: 582
that is not going to be an easy install at all.... needs to be plumbed up to code..the old tank has to lifted over the boiler to get it out....same with new one going in.150.00 bucks....not a chance...
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Strange plumbing to my elec water heater > photos Flt_Simulation Plumbing 17 05-13-2014 04:52 PM
STATE water heater failures SinCityKid Plumbing 5 05-02-2013 10:22 PM
How NOT to install a water heater dengle Plumbing 13 01-29-2013 10:24 PM
