Hot Water Drain Valve Broken - Cannot Empty - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2015, 03:33 PM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
Originally Posted by jmon View Post
Excellent Pugsy, more than one way to skin a cat. Like you said, on a demo site they're no rules. Nice thinking.
Don't know if you're keeping it or trashing it and putting in a new one, but if you do keep it put a new ball valve hose bib on there and you'll be good to go.
Thanks for the update.
Yep. I love the ball valves. I think I will use them throughout the house wherever possible.
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
jmon (06-21-2015)
Old 01-17-2016, 06:58 PM   #17
123pugsy's Avatar
Thought I would update in case anyone is searching for ideas.
Pics below of the new setup.
I used a pipe plug for safety.
Hot Water Drain Valve Broken - Cannot Empty-img_8375.jpg   Hot Water Drain Valve Broken - Cannot Empty-img_8376.jpg
jmon (01-17-2016)
Old 01-17-2016, 09:40 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 188
Looks good, but I suggest another step- replace the plug with a 3/4 MIP x male garden hose adapter. Then add a garden hose cap. Now you're set up to flush it at any time with no additional fittings.
The Following User Says Thank You to TheEplumber For This Useful Post:
jmon (01-18-2016)
Old 01-18-2016, 05:06 AM   #19
123pugsy's Avatar
Thanks.
Sounds good.
Water heater drain valve dionabass General DIY Discussions 2 11-13-2014 05:20 PM
Leaking drain valve in hot water heater rhelfand Plumbing 7 12-07-2012 04:37 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
