Hopefully This One Is Obvious (dishwasher) - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By DR P
  • 1 Post By ddawg16
Old 01-23-2018, 05:46 AM   #1
Rewards Points: 14
Hopefully this one is obvious (dishwasher)
Over the past 2 days, my dishwasher has been really, really loud. We run that thing several times a day for the past few years. It has to be on its last legs. So, last night, I notice a little puddle in my basement, directly under where my dishwasher is. The water is coming through the basement ceiling (wood), and not directly out of a pipe. Gotta be the dying dishwasher, right? I ran the sink and garbage disposal this morning for about 30-60 seconds each. No new drips in the basement. However, when I took a shower this morning in my 2nd floor shower, which is above my kitchen sink/dishwasher, I noticed some new dripping in the basement.
Am I reading too much into this, or is it only the dishwasher that's leaking / dying? Could the water from the 2nd floor shower just be forcing any trapped water under the dishwasher out? Just trying to look at every angle. Thanks for taking time to read this.
ts8586 is offline   Reply With Quote
Old 01-23-2018, 06:10 AM   #2
Guapo
Rewards Points: 11,950
Re: Hopefully this one is obvious (dishwasher)
I imagine that the shower & the dishwasher drains eventually meet somewhere. That's where I would look first. That would be the only connection that I see between the shower & the dishwasher.
Guap0_ is offline   Reply With Quote
The Following User Says Thank You to Guap0_ For This Useful Post:
ts8586 (01-23-2018)
Old 01-23-2018, 06:59 AM   #3
Peace be with you
DR P's Avatar
Rewards Points: 1,860
well it sound like your DW isn't getting ant newer...
take kick panel off lower front of DW & inspect for water/wetness
remember power is energized before sticking hands inside
perform the shortest rinse cycle available
while continuing inspection for water w/flashlight
shutting down DW until replacement
while continuing to use shower should
determine if there is more going on
Peace
ts8586 likes this.
DR P is offline   Reply With Quote
The Following User Says Thank You to DR P For This Useful Post:
ts8586 (01-23-2018)
Old 01-23-2018, 07:08 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 18,410
as noted above....remove the kick plate and have a look.
Personally, I don't think it's the DW......you would most likely see water coming out from under the kick plate.
Don't ignore the issue....a 'little' drip through the wood means there is a lot more water on the other side.
ts8586 likes this.
The Following User Says Thank You to ddawg16 For This Useful Post:
ts8586 (01-23-2018)
Old 01-23-2018, 09:31 AM   #5
Rewards Points: 311
Very true
christoff is offline   Reply With Quote
The Following User Says Thank You to christoff For This Useful Post:
ts8586 (01-23-2018)
Old 01-23-2018, 06:17 PM   #6
Rewards Points: 14
It was a cracked sump pump unit in the dishwasher. Just a coincidence with the shower, I suppose. Thank you everyone for your input.
junction box location and acessibility for dishwasher JKeefe Electrical 10 01-19-2016 07:49 AM
Installing dishwasher, are dishwasher panels needed? Lemkie Kitchen & Bath Remodeling 4 02-24-2015 04:13 PM
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
