Home Shampoo Sink Hook Up Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2017, 05:30 AM   #1
Rewards Points: 2
Talking
How y'all doin? Miss SheFreaka in seattle has a plumbing query:
I'm a hairdresser who would like to work from home. I need a nice shampoo chair and sink to best take care of my clients. I've attached a pic of the sink unit I'd like to use.
Can I rig up the plumbing for this unit to connect with my plumbing under the kitchen sink? Ideally, I'd like a quick release system that I can disable when it's not in use. Is this a feasible reality, or am I just dreaming? I'm open to suggestions and advice.
I'm aware of the other portable sinks out there, but they're either really cheap looking, or a huge square box with 5gal tanks for water underneath. And my clients can only let me dunk their heads under my kitchen faucet for so long. And my kitchen is too "skinny" to use a shampoo board and a chair at the kitchen sink.
Thanks!
Trying to Keep it Classy in Seattle
Home Shampoo Sink Hook Up Question-img_0117.jpg   Home Shampoo Sink Hook Up Question-img_0119.jpg
SheFreaka is offline   Reply With Quote
Old 04-01-2017, 07:19 PM   #2
Rewards Points: 1,942
Re: Home Shampoo Sink Hook Up Question
I would suggest you check into your state licensing requirements regarding the equipment you will need for a home based hairdresser.
And your local building and zoning board.
Ghostmaker is online now   Reply With Quote
Old 04-01-2017, 09:00 PM   #3
Rewards Points: 281
If your state/city says it's fine, then u can plan on locating the sink along the same wall where your kitchen sink is. That way, plumber can extend water supply lines and drain pipes behind the wall.
Druidia is offline   Reply With Quote
Old 04-03-2017, 10:52 AM   #4
Breakin' Stuff
Rewards Points: 1,374
Is this going to be a portable unit? I'm no code expert, but it's my understanding that portable equipment has much more lenient requirements than permanent fixtures. But you probably won't be able to connect it to your sink's drain. You may be able to do quick connects for cold water and hot water, then drain into a bucket or something. If it's a permanent fixture it will probably need to be installed just like any other sink.
Renovations to my 1947 home can be followed here: www.schlosserhouse.com
Bret86844 is offline   Reply With Quote
Question about Vigo 33" Apron sink fitting base cabinet Billm0066 Kitchen & Bath Remodeling 0 02-09-2016 09:57 PM
Undermount kitchen sink installation question ZZZZZ Kitchen & Bath Remodeling 3 08-03-2015 10:01 AM
Kitchen sink plumbing question Lin171 Plumbing 30 07-19-2015 06:29 AM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 08:10 PM
Question about installing plastic sink basket gone_fishing Plumbing 7 06-20-2010 12:24 PM
