Hole Saws - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2015, 07:50 PM   #1
Rewards Points: 248
hole saws
Does a 4-3/8" hole saw produce a 4-3/8" hole, or is that size the "inner diameter" of the saw, so that the hole would be 4-3/8" plus the saw's kerf?
P.S. I'm shopping online, so I can't simply measure one hanging on the sales rack.
diy888 is offline   Reply With Quote
Old 03-13-2015, 08:09 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 248
That is the size of the hole
Old 03-13-2015, 08:10 PM   #3
Rewards Points: 6,334
My experience with hole saws is - yes, the hole will be 4-3/8".
The coupon that stays in the saw will be inside diameter and the difference between inside diameter and outside diameter will be cuttings.
SeniorSitizen is offline   Reply With Quote
Old 03-14-2015, 05:32 PM   #4
Rewards Points: 248
Thanks for this information. It saved me from making the wrong purchase.
The Following User Says Thank You to diy888 For This Useful Post:
SeniorSitizen (03-14-2015)
Old 03-15-2015, 11:12 AM   #5
Household Handyman
Rewards Points: 1,412
Please note that manufacturers of hole saws state that the sizes are "nominal". From experience: Hole saws tend to leave the hole just a bit larger than the stated size of the saw. I have never, ever seen a hole saw and arbor assembly that does not have some wobble to it also.
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 02:52 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 09:57 AM
Cutting out a hole on a stainless steel sink...pics Goldglv General DIY Discussions 14 02-28-2010 10:04 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
