Hole In Lawn Near Septic Tank. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2015, 04:00 PM   #1
Rewards Points: 536
hole in lawn near septic tank.
I've noticed soft spots before but today when mowing I stomped down and my foot went in the ground about 4-5". I kept pushing and you can see the area where grass sunk.
This us near the end of my concrete septic tank. There are no tunnels like moles make in my back yard. This part of Fla doesn't have many sinkholes.
I pushed a tomato stake in the hole and it went down 16" in a couple of spots. Its not wet and doesn't stink.
Any ideas?
Startingover is online now   Reply With Quote
Old 04-22-2015, 04:11 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,940
Start digging and see what is going on. Could be your tank has failed.
The Following User Says Thank You to joed For This Useful Post:
Startingover (04-22-2015)
Old 04-22-2015, 04:13 PM   #3
Rewards Points: 470
If it was mine I would start digging until I found the problem. Is this a fairly new tank? It could just be ground settling. That would be an easy fix.
Jim F is online now   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
Old 04-22-2015, 04:18 PM   #4
Rewards Points: 536
Joed,
Wouldn't I have some kind of trouble, like with drains in the house, or bad odors outside?
This is at the far end of the tank, opposite where the guy opened it to pump it when I moved in. ( 3 yrs ago).
Im able to start digging, but I'm a little afraid.
What would I look for?
Jim,
Its 31 yrs old and there are no trees roots nearby and I had a man who's been in the business for 50 yrs inspect it and he said it was a good concrete tank.
Old 04-22-2015, 04:41 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,238
Ayuh,.... Yer lookin' for a broken pipe, as the dirt falls into it, 'n is carried away by the effluent, hence yer hole,...
The Following User Says Thank You to Bondo For This Useful Post:
Old 04-22-2015, 07:08 PM   #6
Rewards Points: 536
Bondo.
Ok, Ill call the Septic Co, I used to drain the tank, an see who they recommend.
Hope it doesnt cost much.
Now if one spot broke hope other spots don't break.
Old 04-22-2015, 09:01 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
Fill the hole with #2 rock just below the grass line and see what happens. may just be a gap around the septic tank cavity sinking common problem keep an eye on it.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Old 04-22-2015, 10:24 PM   #8
Rewards Points: 536
My lawn looks like it has a belly button.
Javiles,
Ok, I'll buy some gravel an try that.
Old 04-23-2015, 06:38 AM   #9
Bondo's Avatar
Ayuh,.... You say it's 31 years old,..?? That's not settlement, but a Problem,....
Just fillin' the hole, will lead to more stone, 'n soil fillin' the leach field,....
The Following 2 Users Say Thank You to Bondo For This Useful Post:
joecaption (04-23-2015), Startingover (04-23-2015)
Old 04-23-2015, 06:46 AM   #10
Rewards Points: 18,964
Filling will not fix the real problum.
Old 04-23-2015, 12:36 PM   #11
Rewards Points: 536
Ok, I'll dig down a little.
Old 04-23-2015, 01:35 PM   #12
Rewards Points: 1,910
Tell someone to watch while you dig just in case it is one of those Fl sinkholes. We don't want to lose a forum member. Better yet, tell someone to dig while you watch.
The Following 2 Users Say Thank You to jogr For This Useful Post:
MTN REMODEL LLC (04-29-2015), Startingover (04-23-2015)
Old 04-23-2015, 06:25 PM   #13
Rewards Points: 536
LOL,
Seriously, I think thats what scares me.
A couple of yrs ago a man, over near Tampa, was sleeping in his bed an a sink opened and swallowed him. His brother ran in and just saw his arm disappearing down the hole.
I'm going to call someone and if it costs to have them investigate the hole I'll do the digging then.
Old 04-23-2015, 08:33 PM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 248
If you know the depth of your tank lid- thats how deep you'll probably need to dig- plus a tad more to the outlet pipe....
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Bondo (04-24-2015), Startingover (04-24-2015)
Old 04-24-2015, 05:59 AM   #15
Rewards Points: 536
Heres a photo from 3 yrs ago when the inspector marked the tank with white flags and drainfield with yellow flags.
When I watched the tank being drained I'd say its the depth of the tomato stake I poked down, about 18"
From the white flags, now it looks like the hole is on the side of the tank away from the drainfield.
AAV in a DWV system with a septic tank gaaah Plumbing 10 09-20-2011 11:53 AM
All problems have a solution (septic tank resolutions) Snav Plumbing 3 04-23-2010 09:11 AM
Garage over Septic tank and Leach lines canyonbc Building & Construction 11 01-13-2010 10:48 PM
Magnolia tree + septic tank question/problem Jemo General DIY Discussions 5 01-18-2007 09:08 AM
Foundation over abandoned septic tank handyman923 Building & Construction 2 09-29-2005 07:12 PM
