Hole Forming In Yard Near Septic Pump Tank - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By rjniles
Old 08-09-2017, 02:02 PM   #1
Rewards Points: 273
Hole forming in yard near septic pump tank
Recently we noticed the ground beside the pump tank is caving slowly. I slid the cover off and, sure enough, it's right where the discharge line goes out to the drain field. Is it safe to assume the line is leaking at that spot which is causing the ground to become soft and cave? I can dig down to it, but if it is a leak, what is the best way to remedy this?
www.essentialintegrations.com
phuz is offline   Reply With Quote
Old 08-09-2017, 02:14 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Hole forming in yard near septic pump tank
Might not know until you dig it out.
It could be a break in the line or a separation of the components.
The fix would be different for each of those cases.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-09-2017, 02:22 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 876
Fix it soon. You are washing dirt in to you leach field. It will clog it up and you are looking at a large $$$.
joecaption and Nealtw like this.
rjniles is offline   Reply With Quote
Old 08-09-2017, 02:25 PM   #4
Rewards Points: 273
If the leak is from the discharge line, how is dirt getting pulled into the line and sent to the leach field?
Old 08-09-2017, 04:27 PM   #5
Rewards Points: 273
I dug it up and triggered the pump. I didn't see any leak whatsoever, so now i am wondering if it was forming from rain runoff. It just seemed odd that the caving was forming directly over the discharge pipe.
Old 08-09-2017, 05:01 PM   #6
Rewards Points: 18,952
New system?
May be as simple as just the soil settling.
Old 08-09-2017, 05:03 PM   #7
Rewards Points: 273
Originally Posted by joecaption View Post
New system?
Almost 30 years old. But we have had some massive amounts of rain over the last month.
Old 08-09-2017, 05:13 PM   #8
Post a picture so we can see what your seeing.
Uncovered the distrbution box to make sure the cover is not broken?
That old a system it could be Tarra Cotta tile, or Orange Burge leach lines.
Both will fail over time.
Old 08-09-2017, 05:19 PM   #9
Rewards Points: 273
I'll admit I have zero idea where the box would be.
Can't drain electric water heater dubina Plumbing 35 08-02-2017 08:07 PM
septic - could you fill a 1500 gallon tank in 10 months? denemante Plumbing 20 12-10-2012 04:16 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
How big is the opening on top of a septic tank? tomseeley Plumbing 7 06-11-2009 06:04 PM
Install manholes (access) hole in concrete septic tank cover rkpatt General DIY Discussions 2 02-23-2009 06:37 PM
