Hole Around Shower Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-07-2015, 06:49 PM   #1
Hole around shower drain
First time poster here, so please help if you can.
I am attempting to do my own walk in shower, I tore out the prefab shower stall and ran into this: well I guess it wont let me post attachments so I will tell you. Its probably a 10"x10" frame inside the concrete slab, around the shower drain. this is where I need help.
A buddy said that I should get a 4" pvc pipe to place around the drain, fill the outside with quickcrete, and the inside of the pvc with p rock.
Suggestions and would that work?
MN0451 is offline   Reply With Quote
Old 12-07-2015, 07:01 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 168
If the drain body is from a fiberglass unit, it will need to be changed to one that excepts a shower liner- assuming you are doing a tile base.
You should be able to upload an image- but not a link
Old 12-07-2015, 07:16 PM   #3
It wont let me, I click the "insert image" icon and it just asks for a URL of the pic. help?
Old 12-07-2015, 07:33 PM   #4
Plumber
Rewards Points: 168
Scroll down below the Reply to thread box and you'll see Additional Options-
Select the Manage Attachments button. This will prompt you to search your hard drive and upload an image.
You need to be in the Advanced Reply mode to do this- not quick reply- use the brown Post Reply button at the lower left
Old 12-07-2015, 07:33 PM   #5
Rewards Points: 3,220
I think you need 5 posts to post pics. you're almost there.
Click post reply, type a few words, scroll down and click on manage attachments, upload your pics from there. Thanks.
jmon is offline   Reply With Quote
Old 12-07-2015, 07:51 PM   #6
I think I got it now, thanks. This is what it currently looks like.
Old 12-07-2015, 08:19 PM   #7
Rewards Points: 1,856
You need this. And a liner.
http://www.homedepot.com/p/Sioux-Chi...A&gclsrc=aw.ds
How to
Old 12-07-2015, 08:28 PM   #8
What do I fill the hole up with? all quickcrete or a what was suggested to me in my first post?
I was thinking about using a kerdi drain, are they basically the same as the oatey?
Old 12-07-2015, 09:43 PM   #9
The kerdi system is different but the entire shower floor needs to be sloped to the drain before you install the Kerdi membrane. Your Kerdy drain should be the low point. So install it then fill the entire hole as you make the slope let dry then apply the membrane.
http://www.schluter.com/schluter-us/...er-System/c/SS
same as what your using on the floor Quick crete.
Tags
shower base , shower drain , walk-in tub
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
Help: Sewage smell coming from shower drain! erikerikerik Plumbing 23 01-11-2014 02:09 AM
Drain for preformed shower base svaic00 Plumbing 1 05-02-2013 10:11 PM
Need help setting shower drain in existing slab drain hole! deedeedeeIY Kitchen & Bath Remodeling 9 05-11-2012 09:39 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
