Higher P-Trap Routing. Do I Have To Cut Into My Vanity Here? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree7Likes
  • 2 Post By TheEplumber
  • 2 Post By rjniles
  • 1 Post By DR P
  • 1 Post By firehawkmph
  • 1 Post By WalkThisWhey
Old 02-07-2018, 04:02 PM   #1
Rewards Points: 136
Higher P-Trap Routing. Do I have to cut into my vanity here?
My drain 10" off the right side wall. The whole section is 31", so a 30" vanity is snug. Can I route a P-trap to be higher than the drain pipe as is without cutting into this section below it? I was thinking of having an S-pipe but apparently those are against code (read it here)
Higher P-Trap Routing. Do I have to cut into my vanity here?-img_6967.jpg   Higher P-Trap Routing. Do I have to cut into my vanity here?-img_6919.jpg
WalkThisWhey is offline   Reply With Quote
Old 02-07-2018, 04:16 PM   #2
Guapo
Rewards Points: 11,950
Re: Higher P-Trap Routing. Do I have to cut into my vanity here?
Is it an existing vanity or a vanity that you just bought? The reason that I ask is a vanity with a lower floor & drawers on the left would make the installation a lot easier.
Guap0_ is offline   Reply With Quote
Old 02-07-2018, 04:21 PM   #3
Rewards Points: 136
Vanity I bought. I could get a left drawer unit but the ones I've found didn't fit right with the right side door opening. I'm staying with this one.
Old 02-07-2018, 04:32 PM   #4
Rewards Points: 1,735
Sorry but I don't see what the problem is here. You will just need a longer tailpiece coming down off your sink and your p trap will be at the right height. I would take that existing pvc off there and put a 45 on it, an extension, then a SJ trap adapter so it's at least pointing in the right general direction.
XSleeper is offline   Reply With Quote
Old 02-07-2018, 04:45 PM   #5
Guapo
Ok, I thought that there might be an easier way. Here's a pic of a high trap.
https://i.stack.imgur.com/2rcCC.jpg
Old 02-07-2018, 05:13 PM   #6
Rewards Points: 136
https://imgur.com/a/KK9xF
I've added this picture for clarity - unsure if the other pic was making it seem different, but I'm not sure I'm following you.
Old 02-07-2018, 05:20 PM   #7
Rewards Points: 136
I really, really want to do this - is it to code?
Old 02-07-2018, 05:31 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 248
NO
Without opening the wall and raising the tee, your only option is to cut the shelf for the trap
XSleeper and MTN REMODEL LLC like this.
The Following User Says Thank You to TheEplumber For This Useful Post:
Ghostmaker (02-07-2018)
Old 02-07-2018, 08:06 PM   #9
Guapo
Wasn't the pic that I posted up to code? If not, why not?
Old 02-07-2018, 08:29 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
It is an S trap.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 02-08-2018, 07:56 AM   #11
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Install a clean out with a vertical riser.
Install tee for trap/adapter.
Install studor vent above trap arm.
Peace
XSleeper likes this.
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 02-08-2018, 06:59 PM   #12
firehawkmph's Avatar
Rewards Points: 2,584
Take the back piece of drywall off and raise the drain in the wall. Probably take less time then we've spent writing back and forth here. I understand why you wouldn't cut the shelf, the trap would interfere with the drawer. Next time, choose your vanity ahead of time so you know where all the rough plumbing has to go. Not that big of a deal to fix.
Mike Hawkins
SPS-1 likes this.
firehawkmph is offline   Reply With Quote
Old 02-09-2018, 05:38 AM   #13
Rewards Points: 136
Mike Hawkins
Yeah that is ultimately what I will be doing. Going with a plumber to do it since I am on a time crunch and DIYing this for me would take 15x time.
firehawkmph likes this.
Old 02-09-2018, 08:42 AM   #14
Plus a minimum of three trips to the store!😆
Those vanities with the drawer in the bottom are pretty neat. I made one like that for a job a few years back. Toekick was part of the drawer too, didn't waste any space.
Mike Hawkins
Basement Vanity to Vent Pipe?? Paulywog Plumbing 15 12-27-2017 06:37 PM
Hiding plumbing behind vanity in odd space jaketrades Plumbing 3 11-20-2017 09:19 AM
Disposal to P trap Jamesonc Plumbing 16 12-05-2014 03:46 PM
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
