High Flow Exterior Faucet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-21-2015, 10:01 PM   #1
Rewards Points: 4
High flow exterior faucet?
Hello everyone first post here.
I recently added a new sprinkler system fed by the outside faucet. It works great since I ran 3/4 pex to it form main coming into house.
My question is my other faucet I have a 100 ft water hose with two tandem impact sprinklers going to my other side yard on a timer hooked up from a 1/2 line and a frost free sprinkler. It's not putting out enough volume to run the both full force. I replaced the original due to leaking.
So a long winded question is does anybody know of a higher volume faucet I can buy to help with volume?
Pressure is 55 off 3/4 line at 10 gpm. Haven't measured new one.
darktower007 is offline   Reply With Quote
Old 10-22-2015, 02:50 AM   #2
Rewards Points: 6,360
Try a full flow ball valve.
Old 10-22-2015, 06:56 AM   #3
Sometimes referred to as Full Port as opposed to reduced port.
Old 10-22-2015, 11:22 AM   #4
Rewards Points: 4
Okay thanks!
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Water Flow in Kitchen Faucet Cultcab Plumbing 2 08-25-2013 08:26 PM
1/2HP motor: start on low, or high? tylernt Electrical 3 11-16-2012 11:48 AM
High particles, high co2, and high relative humidity robotman2009 HVAC 15 07-26-2012 07:50 AM
Water flow & pressure problems DHughes54 Plumbing 3 04-18-2012 09:09 PM
