Hide Cleanout Plug Behind Drywall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2012, 01:07 AM   #16
Mad Scientist
Whoever did the plumbing in my house here used double-gang electrical boxes with the backs cut out and blank cover plates to hide the cleanouts in the walls. Not a bad way to do it I guess, though low-volt rings would have been easier than cutting up junction boxes.
McSteve is offline   Reply With Quote
Old 01-06-2012, 06:29 AM   #17
Rewards Points: 2,074
Originally Posted by Javiles View Post
I love can't find the clean out calls.. $295.00 later i'll find your clean out.
The old statement pay me now or pay me later but later will cost you much more.
Buy clean out plug without square sticking out and install it then go to HD or Ls and buy a square plastic access panel box (Various sizes) install that and paint to match wall.
COLDIRON is offline   Reply With Quote
Old 01-06-2012, 09:05 AM   #18
Originally Posted by TheEplumber View Post
@ TomU- if you do put in a flush plug with a clean out cover, do not run the anchor screw in further then needed to anchor the cover. If the screw is too long, toilet paper and such will hang up on it and cause a blockage. Then your in deep do-do
FYI, you can get plastic covers that can be textured and painted to match the wall- becomes almost invisible
Thanks, this is what I'll do. If the screw is too long, I'll just get a shorter one or cut it shorter
TomU is offline   Reply With Quote
Old 07-08-2016, 01:45 PM   #19
Rewards Points: 4
Dead threat, just had to put my 2 cents in for ocd purposes.
What you want is a countersunk cleanout plug available in abs/pvc and other materials I cant remember. Also you want a cleanout plug plate which come in various shapes, sizes, colors, and different materials like plastic or metal. I'm 100% positive you figured something out by now in 4 years but I just had to post cause not one person said countersunk. BTW "TheEplumber", that was some great advice about the plate screw, with the countersunk/flush plugs you could totally screw that sucker all the way through the plug, Thanks again!
gimme100bucks is offline   Reply With Quote
Old 07-08-2016, 01:50 PM   #20
Rewards Points: 4
Re: Dead threat, just had to put my 2 cents in for ocd purposes.
*Dead Thread, sorry my bad
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 08:32 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 08:40 AM
