HELP ! Tub Drain Not Long Enough ! - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2015, 11:35 AM   #1
Rewards Points: 6
HELP ! Tub Drain not long enough !
I ahve a 60 year old cast iron tub. I am completely replacing the drain and overflow. Here is my problem...the drain itself that goes into the drain hole and the threads into the part below that is positioned just under the drain hole...The male threaded part of the drain is not long enough to reach the femail part below...the tubs thickness and the shape of the drain hole. I can get maybe 1 05 two threads started but if i try to tighten it pops out of those two threads and comes apart. A plumber at a local supply house saod they used to make a longer one for marble tubs as these tubs are thicker. He also suggested using JB Weld as a plumbers thread sealant...catch the two threads I'm catching and let the JB Weld hold it all together mechanically.
HEEELP ! I have a ome inspection in 6 days
bgiltnan is offline   Reply With Quote
Old 08-04-2015, 04:25 PM   #2
Rewards Points: 1,852
You need a longer male part. forget the JB weld.
Old 08-04-2015, 06:20 PM   #3
Rewards Points: 582
are u using a plastic trip and waste assy...if so ..I would use a brass one..
Old 08-05-2015, 04:43 AM   #4
Rewards Points: 6
Where can I get a longer male drain part
I know a longer drain part wou;ld solve the problem...that is the problem...I can not find a longer one...any ideas ?
Old 08-05-2015, 06:24 AM   #5
Retired Moderator
Rewards Points: 7,174
Can you post a picture? JB weld is a poor idea----
Old 08-05-2015, 12:48 PM   #6
Rewards Points: 767
Are you trying to screw it together while the trip waste is all put together. Try taking out the piece that the strainer screws to and attach it that way.
ct18 is offline   Reply With Quote
Old 08-05-2015, 05:57 PM   #7
Get a Brass tub waste.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (08-05-2015), oh'mike (08-05-2015)
Old 08-05-2015, 07:28 PM   #8
Rewards Points: 582
are you using a plastic drain assy????? yes or no...
Old 08-06-2015, 09:00 AM   #9
Rewards Points: 6
More on tub drain
I am using a high quality brass assembly...I have about convinced myself that there might be a hardened gasket on the underside that I need to remove...I am going to hit the underside with a surface grinder and see if it is metal of a gasket...sure feels like metal. The thread extension on my drain is almost exactly 1 inch...I think i need alost 1.5 inches to get teh parts to thread into each other
Old 08-06-2015, 05:29 PM   #10
Rewards Points: 582
I have never seen a brass assy not work on a castiron tub...40yrs and counting...
Old 08-06-2015, 06:26 PM   #11
Post the name of this brass assembly please.
Old 08-28-2016, 02:00 PM   #12
Rewards Points: 2
Re: HELP ! Tub Drain not long enough !
Maybe too late, but a decent machinist might be able to make a brass extension for you.
Burnt Ice Cream is offline   Reply With Quote
Tags
longer tub drain , older tubs , tub drain
Very old scupper drain system presents unique replacment challenge-PICS mysterylectric Roofing/Siding 0 10-26-2012 08:05 PM
AC Drain clogged - goes into concrete - no drain outlet at outside evap unit = ???? ReEstate-Rookie HVAC 4 08-27-2012 08:51 AM
washing machine drain issues lost_punk Plumbing 2 06-19-2012 10:18 AM
New Drain and Overflow assembly not fitting properly to new tub - Help plz amodoko Plumbing 19 12-21-2011 02:28 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
