Help Trace Hot Water Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2016, 02:29 PM   #1
Rewards Points: 37
Help trace Hot Water pipe
I have a 3 story rental on a slab that I am trying to separate out the hot water lines.
Currently 2 water heaters (connected in parallel) distributes hot water to 3 families. There has always been a shortage of hot water in colder months.
Hot water Heaters are located in the garage/utility room. Hot water pipe goes up and over to ground floor unit and then I assume is split to go up to the upper 2 units.
Is there a way to see the hot water pipes without tearing up the walls/ceilings? Does anyone have experience using the Flir I7 Thermal Camera they rent from the Home Depot?
Any other ideas to solve my issue welcomed.
Thanks in advance.
jay235 is offline   Reply With Quote
How to apply caulk to seal water pipe through basement wall goshenplumber General DIY Discussions 4 07-08-2013 08:40 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 01:53 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 05:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
