Help With The Right Fitting.. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
Old 03-12-2018, 07:13 PM   #16
Rewards Points: 8
Why would replacing a tailpipe and running a hose into the cabinet and looping it take any longer??
Nealtw likes this.
Rgbaseball is offline   Reply With Quote
Old 03-12-2018, 07:23 PM   #17
retired framer
Rewards Points: 15,596
Re: Help with the right fitting..
Originally Posted by Rgbaseball View Post
I want to eliminate this but reroute the hose about 5 feet further away.. what can I run this in to make that happen what fittings to PVC?? It is a drain for a dish washer..
While everyone is here what is code about the white and black connection
Considering it is in the area of the breaker box.
Nealtw is offline   Reply With Quote
Old 03-12-2018, 08:18 PM   #18
Rewards Points: 8
Gregs- Not sure if you're being sarcastic or if I didn't do something right..
Old 03-12-2018, 08:28 PM   #19
retired framer
I think it was a compliment on how fast as most people would have asked another dozen questions and talked for 2 days.
Old 03-12-2018, 08:30 PM   #20
Rewards Points: 8
Ok had me worried.. going to get another pipe away from the electrical box tomorrow.. again thanks so much for the help.. The responses are very helpful
Nealtw likes this.
Old 03-12-2018, 08:39 PM   #21
Rewards Points: 88
No sarcasm at all. Just glad to see you have come back and are willing to learn how to tackle your own homes problems, which is always a positive. True grit factor in play.
Gregsoldtruck79 is offline   Reply With Quote
Old 03-12-2018, 08:42 PM   #22
Rewards Points: 8
Thanks. And thank you for all the help.
Old 03-12-2018, 09:15 PM   #23
retired framer
Originally Posted by DR P View Post
not sure that was ever a code acceptable drain connection...
if you are moving DW, would be correct time to make compliant.
if so, where is new DW location in relation to kitchen sink location?
Peace
Is there a code issue with the black and white drain pipe here.
Old 03-13-2018, 04:18 AM   #24
Rewards Points: 88
I think it will help the posters here to see what the OP is working with.
http://www.diychatroom.com/f15/framing-help-602953/
And to see that really, he needs to work on the most present and clear dangers first. Like the DW discharge hose in front of his breaker box and his 3/4 in. main water service line and old valve being located right over his breaker box. And some other weird hanging metal pipes I see.
So I say, lets everyone help him stay focused on these issues getting worked out and then, help him with the lesser issues like the ABS/PVC connections. If he still has the monies and energy to spend, and still wants our help by that time. JMO
Old 03-13-2018, 08:43 AM   #25
Rewards Points: 8
Well thanks to all the help on the original post i have the two pipes above the electrical panel removed.. thanks again guys.
Gregsoldtruck79 likes this.
Old 03-13-2018, 01:40 PM   #26
Rewards Points: 88
Looks better RG..
Now sometime when you are not busy, pull those yellow 12-2 NM cables and any others out ....and get them ran behind that drain pipe.
Old 03-13-2018, 01:49 PM   #27
Rewards Points: 8
That's next on my list.
Compression Fitting Leak ulrichfolkers HVAC 24 09-03-2014 08:15 AM
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
