Help With The Right Fitting.. - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
Old 03-12-2018, 12:30 PM   #1
Rewards Points: 8
Help with the right fitting..
I want to eliminate this but reroute the hose about 5 feet further away.. what can I run this in to make that happen what fittings to PVC?? It is a drain for a dish washer..
Rgbaseball is offline   Reply With Quote
The Following User Says Thank You to Rgbaseball For This Useful Post:
Nealtw (03-12-2018)
Old 03-12-2018, 12:48 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,736
Re: Help with the right fitting..
Originally Posted by Rgbaseball View Post
It is a drain for a dish washer... I want to eliminate this but...
Route the DW drain line to the kitchen sink trap.
Old 03-12-2018, 12:49 PM   #3
Rewards Points: 8
Through the cabinets or back through the floor?
Old 03-12-2018, 12:52 PM   #4
Peace be with you
DR P's Avatar
Rewards Points: 1,860
not sure that was ever a code acceptable drain connection...
if you are moving DW, would be correct time to make compliant.
if so, where is new DW location in relation to kitchen sink location?
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 03-12-2018, 12:53 PM   #5
MarginallyQualified
Through the cabinet.
the fitting you need is a new tailpiece
Old 03-12-2018, 02:09 PM   #6
Rewards Points: 8
Dr.p it is about 3 feet next to it.. I am working on making this compliant. Trust me I have a few more to take care of thanks to the previous owners..
Old 03-12-2018, 02:37 PM   #7
Rewards Points: 88
Your DW can pump 3 + feet easily. Here is my under sink DW drain hose connection. And my goofy sketch of how the DW hose is ran under my sink.
Gregsoldtruck79 is offline   Reply With Quote
Old 03-12-2018, 02:57 PM   #8
Peace be with you
DR P's Avatar
as long as DW hose loops up to as high to underside of counter top
as shown by Greg's picture, I don't think it matters whether drain runs
under floor or through cabinets (given it is not right beside sink)
Peace
Old 03-12-2018, 04:18 PM   #9
Rewards Points: 8
It's next to the sink what's wrong with that? Should I take it down through floor
Old 03-12-2018, 04:34 PM   #10
Peace be with you
DR P's Avatar
I want to eliminate this but reroute the hose about 5 feet further away...
if DW is next to sink then how is it 3' away?
SO - why do you want to move the hose 5'?
did you move your DW or not?
did or does DW hose go through floor now?
Peace
Old 03-12-2018, 04:40 PM   #11
Rewards Points: 8
In the original post I was going to move it 5 feet from where it was because it tied in to drain above electrical panel.. the center of the dish washer is almost exactly 3 feet from where it ties in to the sink drain.
Old 03-12-2018, 06:11 PM   #12
Rewards Points: 1,990
I would also be concerned with the two different plastic being used. They are not designed to be glued together.
Old 03-12-2018, 06:44 PM   #13
Rewards Points: 88
No, not down through the floor. ....residential DW's should be drained as I posted pics of above to remain code worthy. Either use what is called a "high loop" in the DW drain discharge hose in the kitchen cabinet or as I did, install an air trap. Either method used, the DW hose will terminate on the angled DW tap on the side of the vertical tailpiece, shown on the sinks bowl vertical drain pipe. See pic of a chrome one or my PVC one, above.
See the sketch for when a sink discharge hose will not work out.
Old 03-12-2018, 06:59 PM   #14
Rewards Points: 8
Awesome I took it into my cabinet and did the high loop. To the top of the cabinet and then to the tail piece.. thanks for the help
Old 03-12-2018, 07:10 PM   #15
Rewards Points: 88
Dang RG, you did all that re-piping of your sinks drain and relocation of the DW discharge drain hose in just 2 hours ? Man, you need to be in the plumbing business !
Mike Milam likes this.
Compression Fitting Leak ulrichfolkers HVAC 24 09-03-2014 08:15 AM
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
