Help With Plumbing Exhaust In Attic - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2015, 01:12 PM   #1
Rewards Points: 6
Help with plumbing exhaust in attic
I have two problemís Iíd like to ask for opinions and help with.
I was up in the attic searching for a leak that is causing the following pattern on a patch of ceiling right beneath a plumbing exhaust stack.
[Picture 1]
This has developed slowly over a period of maybe 5 years since the last time I thought I fixed the issue. I couldnít see any obvious issues Ė no damp spots, leaks in roof. But it is right near an exhaust stack so I was wondering if water could be condensing on the outside of the exhaust pipe and getting into the ceiling over time.
While up in the attic I saw this on a separate exhaust stack (not the one near the ceiling damage):
[Picture 2]
Questions:
- How concerned should I be about this?
- Is this something I can fix myself or am I better off just calling a plumber? Iím handy and willing to try new things but get a little nervous about dealing with things that go out of my roof.
- If I can fix myself, how should I go about fixing?
Is it possible that this break is somehow contributing to the original problem?
Thanks for any help or ideas.
John
Help with plumbing exhaust in attic-picture1.jpg   Help with plumbing exhaust in attic-picture2.jpg
jfstahl83 is offline   Reply With Quote
Old 12-30-2015, 02:21 PM   #2
Rewards Points: 3,220
Couple things; Looks like vent stack came apart. (Offset). Where reducer meets pipe going through roof. Could just be pic.
Also check where it exits the roof. The rubber boot may have failed. May want to get a roofer and plumber.
I would fix it. Because along with water damage there is also the posibilty of sewer gas leakage.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
Ghostmaker (12-30-2015)
Old 12-30-2015, 04:04 PM   #3
Rewards Points: 6
Thanks for the fast response.
Yes, it definitely came apart. I don't think there is any roof damage because I haven't seen any evidence of water stains.
Old 12-30-2015, 11:10 PM   #4
Rewards Points: 1,856
You can cut the steel pipe and use a proflex steel to plastic coupling you will need a 3 by 1.5 inch coupling piece of 1.5 inch pipe and piece of 4 inch pipe to put out roof. You may need to replace your roof seal if it is not neoprene rubber.
Old 12-31-2015, 06:52 AM   #5
Rewards Points: 6
I live in Chicago and there's a lot of snow and ice on roofs right now. Am I better off waiting until the weather is warmer to fix this?
Old 12-31-2015, 09:44 AM   #6
Then find a big all rubber fernco to make a temporary patch. That way the water will stop messing up your drywall.
OK to insulate plumbing vent in attic before building soffits? FileOpen Insulation 5 09-29-2015 11:01 PM
Attic Plumbing ronney Plumbing 0 07-18-2015 05:46 PM
Looking for an attic exhaust fan smaller than 14". realtx429 HVAC 5 05-01-2012 12:01 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Wondering if it makes economic sence to replace a bathroom exhaust fan ChrisJJ HVAC 0 06-14-2011 10:36 AM
