Help Please..not Enough Thread Left To Attach Water Supply Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-30-2015, 08:34 PM   #1
Rewards Points: 324
Help please..not enough thread left to attach water supply line
Can anyone please give me any suggestions on attaching the water supply line to a new Moen faucet. I replaced my old vanity top with a new one & also am adding a new faucet & I have run into a snag. There is not enough thread left to attach the water supply line after screwing on the wing nut as tight as possible. The new vanity top is quite thick & once the wing nut that holds the faucet is tightened, there is not enough thread left to tighten the water line enough so it won't leak. Any suggestions please? Thanks
dommm is offline   Reply With Quote
Old 07-30-2015, 08:47 PM   #2
Rewards Points: 582
wing nut is plastic i think...need a old style faucet nut and washer...its only about 1/8 " thick..
Help please..not enough thread left to attach water supply line-rp9519-b1.tif.jpg   Help please..not enough thread left to attach water supply line-t-s-bl-5500-07-panel-supply-nipple-lock-nut-washer-2-1-8.jpg
The Following 3 Users Say Thank You to ben's plumbing For This Useful Post:
dommm (07-31-2015), SHR Plumber (08-01-2015), TheEplumber (07-30-2015)
Old 07-30-2015, 08:58 PM   #3
Rewards Points: 324
Thanks for the tip. I will give it a try & yes the wing nut is plastic.
The Following User Says Thank You to dommm For This Useful Post:
ben's plumbing (07-30-2015)
Old 08-02-2015, 07:33 AM   #4
Rewards Points: 324
I went to Home Depot & they had the copper nut but not the square or round washer. I also tried a plumbing supply store for the washer but no luck there either. Anyway, I bought the nuts & pulled the faucet forward as far as possible so the faucets threaded pipes we touching the forward end of the drilled holes & then screwed the nuts on. The nuts have just enough material to catch the edge of the vanity top & I was able to tighten them without the faucet slipping backwards & so far the faucet seems to be holding solid. That gave me enough thread left over to screw the water supply line on & get a good seal. Hopefully it holds & thanks for the tip!
Service pit for main water supply and sewer line sonnaps Plumbing 3 07-23-2015 10:54 AM
Code question about water supply line mprice214 Plumbing 4 09-13-2014 10:28 AM
Refrigerator Ice Maker Water Supply Line marcus118 Plumbing 20 04-02-2014 08:02 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Relocating water supply line from well Mikedks Plumbing 6 09-22-2006 01:41 PM
