Help With Offset Closet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2016, 04:56 PM   #1
Rewards Points: 20
Help with offset closet flange
Well been awhile since my last post and all went perfect thanks to DIY Chatroom . I have an issue with my toilet flange would like to move it over an other three inches at least maybe abit more but it will hit my floor joist . I have full access top and bottom and i was thinking of using Soux Chief 889-AOM full flush offset flange full flow . Should i notch joist just what i need to fit the Soux 889 and then reinforce opposite side . I have a picture from the top down showing what i would like to do . Any suggestions or other options iam all ears . Thanks
Garryo is offline   Reply With Quote
Old 06-07-2016, 10:35 AM   #2
Rewards Points: 98
Re: Help with offset closet flange
If the joist is what is visible through the hole in the plywood, then change your plans about the location of the toilet. Notching that joist sufficiently to fit the flange will likely weaken it too much.
epsilono is offline   Reply With Quote
Old 06-07-2016, 11:21 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Cut out the joist and install a double header on both sides of the cut off.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 06-07-2016, 04:47 PM   #4
Rewards Points: 20
When looking thru the hole that is my suspended ceiling tile . The green tape is my floor joist running from top to bottom in picture hard to see the writing .
Old 06-08-2016, 07:27 PM   #5
Rewards Points: 1,852
I agree just header the joist off on both sides. PS size of joist is needed to tell you if you can cut on it.
Old 06-11-2016, 12:02 PM   #6
Rewards Points: 20
Thanks for the replies , i decided to offset the flange so it is on the edge of the joist a little out of center but not a show stopper .
Mounting of offset closet flange richapple Plumbing 3 11-07-2013 08:07 PM
Broken closet Flange Paul8434 Plumbing 2 12-04-2012 07:08 PM
Offset closet flange pjm30043 Plumbing 31 05-23-2012 07:53 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
