Help Needed Please To Remove A Culligan Medallist Contrl Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2015, 07:08 AM   #46
Rewards Points: 324
Originally Posted by Akpsdvan View Post
New Resin does have some charge but not a full charge, and depending on water quality it could do more damage than good by running with out the first full charge.
Also the first regen is good to flush out broken beads and any dies from the making of the resin.
Also makes sure that the media bed in packed and ready to give the best that it can.
I just keep learning. I hope after all this, I haven't done "more damage than good" because my house water has been running through the resin for 2 days now. How do I make sure the media bed is packed? thanks
dommm is offline   Reply With Quote
Old 05-05-2015, 10:09 AM   #47
Water Treatment
Akpsdvan's Avatar
Rewards Points: 1,184
Using the water over the last few days has packed the bed down so no worries there.
Just push the regen now and have it go through a cycle.
Is there still water in the salt tank for a brine?
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
dommm (05-05-2015)
Old 05-05-2015, 07:28 PM   #48
Rewards Points: 324
OK, so I ran a manual regen right after reading your above post & it seems to have completed without issue so this thread for me comes to an end & I will once again thank you Akpsdvan for all your help & guidance.
PS: yes there was water in the brine tank
Take care
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Hi, Newbie for this site to find way to remove toilet valve wfang New Member Introductions 2 01-04-2009 03:27 PM
please help me remove toilet valve made of plastic wfang Plumbing 3 01-02-2009 08:55 PM
Unable to remove Shower valve abacuslearns Plumbing 8 10-27-2007 10:10 AM
