HELP. Kitchen DISPOSAL Too Low To Waste Line - - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
Old 02-25-2018, 07:20 AM   #16
Rewards Points: 2,074
Re: HELP. Kitchen DISPOSAL too low to waste line -
I just went through the same thing. I remodeled my kitchen and installed the disposal. Went to do the final finish pipe and the drain line was to high. The right way to fix it would be to pull that dishwasher out and start dropping the line from the right side of the dishwasher over to where it comes out behind the cabinets. You should be fine and have enough pitch. Demolition required. I know it sucks but look at it this way it's hidden from view and your lucky enough to have a solution. No body will even know it. You will feel better knowing it's pitched correct and never have to worry about it. Good luck.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
waste line codes TarheelTerp Plumbing 3 01-29-2012 05:59 PM
fork stuck in kitchen garbage disposal and unjammable blackcheetah Plumbing 15 01-16-2012 10:51 PM
repair of broken dwv line from kitchen to the main. docwatson Plumbing 8 05-06-2009 11:14 AM
Blockage in kitchen water line. Local Yokel Plumbing 6 03-18-2009 10:34 PM
