Help Identifying Pipe And Fix - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2015, 11:57 AM   #1
Rewards Points: 114
Help Identifying pipe and fix
Hello all,
This is in my basement. Previous owners had ran the bathroom exhaust fan into this. I went to remove that and try to run it outside on its own. However when I did that the pipe itself started leaking from the taped joints.
Can someone identify exactly what this is? and what steps should be done to fix it? Its the pipe on left.
*not sure why pics are sideways,sorry
Help Identifying pipe and fix-20151031_122934.jpg   Help Identifying pipe and fix-20151031_122924.jpg   Help Identifying pipe and fix-20151031_122946.jpg   Help Identifying pipe and fix-20151031_122915.jpg
cwags is offline   Reply With Quote
Old 10-31-2015, 12:06 PM   #2
Civil Engineer
Rewards Points: 5,246
That is some amazing hack job. The pipe appears to be standard PVC, normally glued together. You can see where the pipe was glued, the purple is the primer. PVC is easy to glue together, you first clean the bell and spigot using pipe cleaner, then you prime (some people don't bother, I always do) using the purple primer, then you put on the glue, then you push the pipes together and hold for a few seconds. All done.
I would take the pipes apart where they are taped and glue them correctly. If the pipes are damaged, simply replace them.
Old 10-31-2015, 12:37 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 182
Is this system for an exhaust fan? Does it pipe to the exterior or connect to something?
Old 10-31-2015, 12:41 PM   #4
Rewards Points: 114
I'm pretty sure it runs to the roof. I don't see why if it was for bathroom exhaust it would run into the slab
Sent from my SM-N910V using Tapatalk
Old 10-31-2015, 12:52 PM   #5
Plumber
Rewards Points: 182
What I'm not clear on, is the tee in the line. From my knowledge, each fan should pipe independently to the outside.
If it comes from the slab, it may be that someone tied into a sub-slab passive radon system- which is not good.
Like Daniel said, PVC needs to be glued at the joints and it kind of looks like some of the material has different outside diameters- making glueing the joints impossible.
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (10-31-2015)
Old 10-31-2015, 01:23 PM   #6
Rewards Points: 582
yep a big hack job...and as e said that looks like its tied into the radon systemmust be corrected
Old 10-31-2015, 01:27 PM   #7
Rewards Points: 114
Do all Radon systems have a fan on that line somewhere? I'm tracing it to the roof but no fan anywhere. House was built in 1993
Old 10-31-2015, 01:44 PM   #8
Rewards Points: 114
Opened up on other side. Looks like where it turns to go upstairs it is glued. So maybe they hacked this part up to just add bath fan? Checked in attic no fan on this line. Help Identifying pipe and fix-uploadfromtaptalk1446317022518.jpgHelp Identifying pipe and fix-uploadfromtaptalk1446317047679.jpgHelp Identifying pipe and fix-uploadfromtaptalk1446317064847.jpg
Old 10-31-2015, 02:17 PM   #9
Plumber
Rewards Points: 182
The more you show us, the more I think it's a radon system. And no, I don't think they all need fans.
Identify the type of pipe- if if says SDR 35 or 3034 on the original pipes, then it is probably radon. That would explain why the fitting appears larger too- it's a sch 40 drain fitting- larger OD pipe.
I suggest you remove all the remodel stuff, reassemble to original. Then redesign your exhaust fan on a separate line to the exterior
Old 10-31-2015, 02:36 PM   #10
Rewards Points: 1,866
Looks like a radon vent that is tied into you storms. Glue it back together removing the open tee. Pipe your vent fan with flex pipe used for dryers to the outside using a dryer vent with a swing door or screen
Old 10-31-2015, 02:40 PM   #11
Rewards Points: 114
Yep there is a gap around existing tee. And I have aa 3" 45 elbow laying around and that's also too big. Do the home centers have the correct fitting?
Old 10-31-2015, 02:55 PM   #12
Rewards Points: 114
It's just the tee that was taped on. Above that under tape is still glued. Looks like I just need 2 couplings and piece of pipe. Could I use 2 fernco couplings since the existing pipe is smaller than standard 3" I can find at home centers?
Old 10-31-2015, 02:56 PM   #13
It may be thin wall piping on the Radon vent you need SDR 35 fittings and pipe. If the one to big is SCD 40 DWV stamped. Look closely you should find the rate stamp.
Old 10-31-2015, 03:48 PM   #14
Rewards Points: 114
Of course the piping is stamped down below against drywall. So I'd have to cut more drywall to see. This is what I did for now. I could not find any other fittings.Help Identifying pipe and fix-uploadfromtaptalk1446324517977.jpg
Old 10-31-2015, 05:22 PM   #15
Only radon that should work fine... Now no holes right?
