Help Identifying Circa 1993 Faucet On Jacuzzi Style Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-16-2015, 04:16 PM   #1
Rewards Points: 14
Help identifying circa 1993 faucet on jacuzzi style tub
Help,
I need help identifying some faucets that I have in my house which was built in 1993. I am remodeling the master bath part of which is replacing the faucets for the sinks as well as the jacuzzi style tub. On the tub however I don't have access to change the rough in valve, so I want to stay with the original brand so that all I need to change is the trim kit. Problem is I cannot seem to identify the brand of the existing faucets. I have attached a pic of tub faucet, any help with their identification would be great.
kb-mudman is offline   Reply With Quote
Old 11-16-2015, 05:20 PM   #2
Rewards Points: 582
sure looks like a delta....pull cartridge to be sure...
Old 11-16-2015, 05:56 PM   #3
Rewards Points: 14
Thx for the reply...
The problem is that I don't have a access panel to the cartridge. I am hoping to just replace the trim kit as everything functions fine, just want to update the look. the gooseneck doesn't have a set screw to remove it like some do...
Any additional help would be appreciated...
Old 11-16-2015, 06:02 PM   #4
Rewards Points: 1,844
The cartridge is under the handle trim.
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
kb-mudman (11-16-2015)
Old 11-16-2015, 06:12 PM   #5
Rewards Points: 14
Any clue how to remove the gooseneck if there isn't a setscrew scenario?
Old 11-16-2015, 06:27 PM   #6
See if that big white thing by the bottom of the spout unscrews.
On the Gold trim aerator is there any printing..
Old 11-16-2015, 06:31 PM   #7
Rewards Points: 14
I didn't see any printing on the gold aerator. I'll give that a closer look and try the unscrewing when I get home tonight. I appreciate the help!
Old 11-16-2015, 09:34 PM   #8
Rewards Points: 14
for what it's worth here are a couple of pics with the handle removed showing the cartridge.
Help identifying circa 1993 faucet on jacuzzi style tub-20151116_192517.jpg   Help identifying circa 1993 faucet on jacuzzi style tub-20151116_192538.jpg
Old 11-16-2015, 09:59 PM   #9
Rewards Points: 14
I was unable to unscrew the large white piece at the base of the gooseneck. This exposed a setscrew which I assume will allow me to remove and replace the gooseneck...
Old 11-17-2015, 11:39 AM   #10
Rewards Points: 14
Are these pics enough to identify the brand or do I need to take them out?
-Thx
Old 11-17-2015, 05:34 PM   #11
Looks like moen cartriges. My guess is you got a moen.
1-800-Buy-Moen
Call them and see if they can suggest trim.
Old 11-17-2015, 07:12 PM   #12
Rewards Points: 582
you have a delta faucet....
Old 11-18-2015, 05:07 PM   #13
It's a delta. My bad.
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
Serial number - Age of A/C JJboy HVAC 0 07-14-2012 08:48 PM
Selecting a New Kitchen Faucet klumbsy Kitchen & Bath Remodeling 4 02-25-2011 08:29 AM
Delta's new style DST faucet, thoughts? djryval Plumbing 0 01-29-2010 10:47 AM
