Help With Gas Log Lighter Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2016, 07:44 PM   #1
Rewards Points: 4
Help with Gas Log Lighter Install
Hi everyone.
I have a fireplace with a natural gas stubout inside for a log lighter. I finally purchased a universal .5" lighter pipe from Lowe's. I never realized, but the stub out literally has no clearance. I can't get a 90 on to give me enough room for install of the mixer on the gas log lighter. I have called around my town and nobody understands what I'm saying. Lol I attached a picture. Please Help an amature!!! Thank you all
7586jongb is offline   Reply With Quote
Old 12-11-2016, 07:53 PM   #2
Rewards Points: 4
Re: Help with Gas Log Lighter Install
Here is a picture of the lighter pipe
Old 12-11-2016, 07:55 PM   #3
hkstroud's Avatar
Rewards Points: 6,684
Well, tell us what we are looking at.
hkstroud is offline   Reply With Quote
Old 12-11-2016, 10:01 PM   #4
Rewards Points: 80
The picture isn't showing up well for me. But i see a sub with some vicegrips. Is this the part you're talking about?
If it is, you're pretty much SOL. You'll need to redo the pipe inside the wall. You might get lucky and get a screw driver under it to pry gently, but it's going to be fairly frail after all this time in the fire.
These kits don't seem so safe to me, but I'm only a professional. If this was mine, I'd want a lockable shutoff to it so that only I could turn it on. But, then again, I'd probably use a whole spark ignition, safety valve kit.
Cheers!
supers05 is offline   Reply With Quote
Old 12-12-2016, 10:26 AM   #5
Rewards Points: 4
Darn. That's sort of what I thought
The 1/2" line with the vice grips on it is my stub out from the brick inside the firebox connected to the valve on the wall. I showed that 90 elbow as a reference to show what little clearance from the floor I have. I don't get it. How would they have built it like this? All my neighbors have the same setup, just higher. You can tell it was used before I bought the place 8 years ago. Here are some more pics just in case it helps someone help me lol.
Help with Gas Log Lighter Install-img_20161211_130425.jpg   Help with Gas Log Lighter Install-img_20161211_081821.jpg   Help with Gas Log Lighter Install-img_20161211_081831.jpg
Old 12-12-2016, 05:31 PM   #6
Rewards Points: 80
You'll be able to get a coupling on it. You might have to go straight across and elbow back around. The longer pipe will give more flexibility.
Cheers!
Old 12-13-2016, 09:49 AM   #7
Rewards Points: 4
Thanks Supers05! I managed to get a longer fitting on to give me enough slack for a 90. Worked great. Thanks for the help
Looking for help on how to install recessed soffit. Snoopy_ Roofing/Siding 2 09-04-2012 03:45 PM
Oak stair tread and riser install tips MTWI Carpentry 6 05-04-2012 05:46 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Aprilaire 560 Install Questions MisterTFM HVAC 4 12-15-2011 12:35 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
