Help Finding Rough In Plubing In Basement Slab - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 2 Post By SeniorSitizen
Old 01-14-2017, 08:48 AM   #1
Rewards Points: 40
Help finding rough in plubing in basement slab
Im trying to find a waste pipe to tap into for a new tub I'm installing in our basement that has a 4" concrete slab. House is 8 years old.
The red dots are drains that i have at the moment and have access to, the blue dot and line is where i need to install the new tub drain.
Yellow lines are me guessing where the pipes run.
Drain 5 (3"pipe) comes down in a partition wall from the upstairs sink but then comes out (they obviously roughed it in slight out when then built the house) of the partition and into the concrete. This would be idea but as its under the partition im not sure i can dig out enough to get to it underneath. If that pipe goes down vertical far enough i maybe can but if it goes like i think following the yellow line then its gonna have a 90' bend on it and run under the partition back towards the soil stack
The second picture is looking at the drain 5 in the direction of the arrow.
Would appreciate anyone's thoughts on this and the best way to find the pipes and run the new drain.
thanks again
Si
Fcat is offline   Reply With Quote
Old 01-14-2017, 08:54 AM   #2
Rewards Points: 6,334
Re: Help finding rough in plubing in basement slab
Run hot water through to determine if a infrared thermometer or camera will pick up a temperature difference at the floor surface.
SeniorSitizen is offline   Reply With Quote
Old 01-14-2017, 08:55 AM   #3
Rewards Points: 40
Thanks for the reply, would that really work with a 4" slab plus soil etc ? i will certainly give kit a go
Old 01-14-2017, 09:02 AM   #4
That's the best I can do for now unless a tracer wire was run with the pipe or a penny was glued to the pipe about every foot so a metal detector could locate it.
TheEplumber and Fcat like this.
Old 01-14-2017, 09:53 AM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
FCAT.....
I've had the very same problem for some additions......
I rent a Shonstedt metal detector and snake a small magnet thru existing drains. Works like a charm.
These detectors are very pricey to buy (range of $500 to $1000+). I don't think normal rental yards have them... maybe.... but I got mine from a surveying instrument shop.....
Or maybe a surveyer will just come buy and check for you.
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 01-14-2017, 11:54 AM   #6
Rewards Points: 40
Originally Posted by MTN REMODEL LLC View Post
FCAT.....
Good luck
Thanks, i know Home Depot dont do anything so will check out a few places around and see what i can find. this sounds like a sure fire way though
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Basement Rough in PSULion55 Plumbing 1 02-06-2010 12:44 AM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 12:52 PM
Cellar to rough basement? javamom Remodeling 1 06-27-2006 04:23 PM
How to get a rough quote on a basement?? cloudkicker101 Building & Construction 4 04-18-2006 11:48 AM
