Help! Extending PVC Pipes The Shortest Way Possible - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2015, 06:32 PM   #1
Rewards Points: 261
Help! Extending PVC pipes the shortest way possible
Hello and thanks to all.
Long story short.. Remodel going from siding to stucco..The net is anything sticking out of the house is shorter due to stucco being thicker than siding.
Have some 3" PVC vents that had a weatherproof/bug proof covers on them.. With the siding I had a 1/2 inch or so sticking out of house ..
With the thicker Stucco it is now flush with the house and no room for the covers to slide over as they covers attach to the oustide wall
I need to lengthen them as short as possible so the covers slide over and the covers are still somewhat close to the house.
Do they make a fitting that..
On one end would go over a 3" pipe and on the other end would be the exact same outter dimensions of a 3 inch pipe ? I can not find it if they do.
it would almost be like if you wanted to glue 2 3" pipes together but instead of a coupling one end of the pipes was flared ...
or a coupling that goes inside the pipes instead of on the outside....
Again, thanks to all.
beachfront71 is offline   Reply With Quote
Old 12-09-2015, 08:34 PM   #2
Rewards Points: 8,321
At one time my drapery hardware supplier had some special 'inside couplings' for PVC pipe (they slid inside the pipe to maintain a uniform outside). I don't recall whether there was a 3" version or not.
They do: rowleycompany.com/products/PVC-Splice.asp
Looks like they have discontinued the line but still have some stock
Colbyt
Retired drapery and home furnishings installer.
Fact: World-wide 96.5% of Covid-19 victims fully recover
Colbyt is online now   Reply With Quote
Old 12-10-2015, 01:06 PM   #3
Rewards Points: 767
The only thing i know of is a street fitting.
ct18 is offline   Reply With Quote
Old 12-10-2015, 03:35 PM   #4
Rewards Points: 5,348
Cut it back inside the house and use a coupling to add the extension.
Ron
B. Franklin 1759
Old 12-10-2015, 05:02 PM   #5
Rewards Points: 5,614
Well Beach, I just happen to be in town today and stopped by my plumbing supply for a cup of coffee and lots of BS. But prior to having to pull my britches legs up to avoid the deep BS I ask about your dilemma.
To my surprise the answer was quick with no BS. According to my supplier either of these closet ( toilet ) flange pipes of the correct size can be cut to the desired length, slipped into your pipe(s) to make a glued internal coupling for an extension.
Whether it meets any code I have no idea and that's no BS.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Tom738 (12-11-2015)
Old 12-10-2015, 05:07 PM   #6
Rewards Points: 1,862
Yea a 3 inch insert flange....
Ghostmaker is online now   Reply With Quote
Old 12-10-2015, 07:22 PM   #7
Rewards Points: 261
Thanks to all.
I found the part.
For those who care google pipe extender..one side slides into existing pipe, the other side is same ODimension as existing pipe.
Spears happens to make them
Insulating water pipes outside home? daluu Insulation 9 01-11-2013 12:11 AM
Original (?) galvanized water supply pipes replace with PEX, CPVC, copper? TomServo Plumbing 5 11-06-2012 11:07 PM
Replace Steel pipes with Copper thinkfuture Plumbing 2 10-30-2012 12:48 PM
DIY mysteries: WTF is with all the pipes? jules4 Plumbing 12 09-18-2010 03:16 PM
Anoying sound in house water pipes when sprinklers are ON gante Plumbing 1 06-07-2010 06:04 AM
