Help With Electric Tankless Cold Water Sandwich - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2016, 09:08 PM   #1
Rewards Points: 319
Help with electric tankless cold water sandwich
Hello
Please help me comprehend an unfrustrate me with a situation termed "cold water sandwich" (CWS).
In our msster bath is a valve from 2011 that either directs water to the regular showerhead or from overhead. We have an electric, tankless water heater of ample capacity.
My wife or daughter will shower using the regular showerhead and be fine. I will come in 2, 5, 10, 12, etc minutes later to shower, and I get hot water right away for about a minute or 2. I then get very cold water for a while until the hot returns.
I've done some research on the CWS, but it still baffles me as i wait for cold water with a head full of shampoo. How can pipes cool down here in Miamj where our temperatures are always hot. I can understand this occurring in Minnesota, Alaska, etc, but in Miami? I wasnt exagerating about the time gap between the showers. The same situation happens if we reverse the order of showering, with me going first.
Why does this happen? Is it preventable? With a recirc pump perhaps?
NABRIL is offline   Reply With Quote
Old 01-31-2016, 09:25 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,596
My novice opinion. The tankless heat only turns on when water flows. If the unit has been off for while some cold water has to flow before the heat kicks back, thus you get some cold through the unit.
The Following 2 Users Say Thank You to joed For This Useful Post:
jmon (01-31-2016), NABRIL (02-01-2016)
Old 01-31-2016, 09:32 PM   #3
Rewards Points: 3,204
Agree with joed. As far as is it preventable; Possibly, with a recirculating pump as you suggested. It makes sense.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
NABRIL (02-01-2016)
Shopping for New Electric Water Heater Lots of Questions LeakyHawaiiRoof Plumbing 3 11-02-2014 01:18 AM
Trickle of Cold Water Pioneer Bathtub Faucet egawrons Plumbing 0 10-25-2012 11:24 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
