Help Connecting New Drain To Existing Cast Iron Hub - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2016, 10:34 PM   #1
Rewards Points: 146
Help Connecting New Drain to Existing Cast Iron Hub
Recently removed an old sink in the basement to find that the drain for that sink and the drain for the kitchen sink above just let out into an old 4-5" diameter cast iron drain pipe raised about and inch from the concrete floor. No fittings/couplings, just loose. I'm not a plumber but I know that's not right. I'm looking to replace the sink and tie into the pvc line coming from upstairs. However, I need a way to seal it onto the cast iron? How do I connect a 2" pvc line to a 4-5" cast iron line (all waste, no rain or groundwater)?
icandousa is offline   Reply With Quote
Old 12-12-2016, 10:36 PM   #2
Rewards Points: 18,960
Re: Help Connecting New Drain to Existing Cast Iron Hub
Post a picture so we can see what your seeing.
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Tying laundry tub into old cast iron drain tigeraid Plumbing 4 02-13-2013 02:17 PM
connecting clawfoot tub to existing drain line in concrete basement michaelflinn Plumbing 0 07-02-2012 04:48 PM
How should i repair this cast iron drain leak? markcal02 Plumbing 14 10-20-2011 05:03 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
