HELP! Is It Better To Finish Rough In Plumbing Myself Or Have The Plumber Do It? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2016, 07:50 PM   #1
Rewards Points: 2
HELP! is it better to finish rough in plumbing myself or have the plumber do it?
Hi everyone this is my first post,
I am building a kit home so my options are endless, they even come with pre punched walls to run plumbing and electric through.
my issue is I don't know if it would be better (and cheaper) to just have the plumber do the rough in plumbing and I do the rest or have them finish it all.
also what do you think some prices for both would me. the home is around 2500 sq ft with 2.5 bath and kitchen?
bullridingt is offline   Reply With Quote
Old 06-07-2016, 08:24 PM   #2
Retired Moderator
Rewards Points: 7,174
Re: HELP! is it better to finish rough in plumbing myself or have the plumber do it?
Your answer depends on several things---
If it is a permited job (houses usually are) and the plumbers name is on the permit--then let the plumber do the trim out---
If you're listed as the plumber--and you hire out the rough in--then you can perhaps save some cash by doing the final hook ups.
Costs vary by location and site conditions and the reputation of the general contractor.
If you are going to be the general contractor, expect to pay a bit more than a pro--as the plumber will expect some difficulties caused by your inexperience.
SHR Plumber (06-07-2016)
Old 06-07-2016, 08:55 PM   #3
Rewards Points: 18,990
How could it be cheaper if they have do do more work?
We have no idea what your abilities are?
Failed plumbing rough in? ngrimm Plumbing 23 01-25-2016 05:31 PM
Plumbing rough in avg cost - basement bathroom with upflow merryannca Plumbing 4 06-28-2015 07:36 PM
Plumbing Rough In Versus Final Inspection kingbuggy Plumbing 4 06-23-2012 03:48 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 10:06 AM
rough in plumbing psiter Plumbing 5 08-23-2006 05:44 PM
