Help With Attaching Bathroom Drain Pipe. Metal Slip Nut? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By TheEplumber
Old 07-17-2017, 02:27 PM   #1
Rewards Points: 4
Help with attaching bathroom drain pipe. Metal slip nut?
Hi guys,
I am brand new to the forum as a member but have been using the advice here for a little while now. I have been renovating my bathroom and a bunch of articles have really helped me.
So I have gotten to the step of installing my vanity and drain but I am not sure what is on the end of the pipe coming out of the wall. Based on some research it looks like a metal slip joint nut. The previous owners of the house just pretty much had a piece of pvc inserted into the drain and it was no attached to anything.
I was just wondering if you guys could help me with the best way to attach a pvc p-trap drain into this.
Thanks!
nstaab1 is offline   Reply With Quote
Old 07-17-2017, 02:31 PM   #2
Rewards Points: 4
Re: Help with attaching bathroom drain pipe. Metal slip nut?
Figured out how to add images!
Old 07-17-2017, 06:04 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 302
@nstaab1 welcome aboard! Can you scrap off the paint next to the wall (on the pipe)?
My hunch is another compression nut is there, or a lead joint. Let's hope for the nut....
SHR Plumber likes this.
Additional bathroom drain pipe jimderbehr Plumbing 2 07-06-2016 07:42 AM
Broken slip joint nut (metal drain pipe) dgpsf Plumbing 5 05-30-2015 08:28 PM
Bathroom sink: What if p-trap, drain pipe are not in alignment? metazone Plumbing 12 02-07-2014 06:05 PM
replacing vertical drain pipe under bathroom sink nctrojans32 Plumbing 1 11-01-2012 11:57 PM
Bathroom sink drain pipe. butwhydoitalk2u Plumbing 0 04-11-2012 04:01 PM
