Height Of P-trap? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By TheEplumber
  • 1 Post By BIG Johnson
Old 05-18-2017, 10:28 AM   #1
Rewards Points: 58
Height of P-trap?
I'm putting in a washing machine outlet box. The drainage pipe branch that I'm planning on connecting to is ~10' away and 18" above floor.
This means that my P-Trap outlet will be 20.5" above floor (1/4" slope) with a 10' horizontal run.
A number of places specify 6" to 18" P-Trap outlet height.
How critical is it? What will be effected if it is higher?
Borisw37 is offline   Reply With Quote
Old 05-18-2017, 06:29 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 248
Re: Height of P-trap?
The rule you refer to is old but still in place per the UPC model code.
The idea is that the trap is between 6"- 18" above floor. The stand pipe is then 18"-30" long. The idea is to have the top of the stand pipe at 36" maximum. This would equal your other counter top heights.
Example- trap is 6" AFF plus a 30" stand pipe = 36" overall. Trap at 18" AFF plus a 18" standpipe = 36"
IMO, this is old code that needs amendment. I see no problem putting the trap higher than 18" as long as you stay within the 18"-30" standpipe length.
UPC minimum pipe size on a washer is 2", IPC minimum is 3"
MTN REMODEL LLC likes this.
Old 05-22-2017, 12:50 AM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,834
And I find it interesting that washing machines are using significantly less and less water. I' m certainly not a industry knowledgeable person about machines..... but I can't believe any residential machines require anything near a 3" drain.... and a 3'' drain can be darn difficult to run in most conventional framing . ... but god forbid if one should ever overflow.
MTN REMODEL LLC is offline   Reply With Quote
Old 05-22-2017, 02:46 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 18,420
3"? Wow.....
I went through the same issue 16 years ago during my first kitchen remodel
I ended up asking the inspector about it. He gave me the same basic story above....and then said "You have a crawl space, if it was me, I'd put the trap down there so I could access it."
Old 05-22-2017, 05:30 AM   #5
Rewards Points: 898
Maybe they're pumping faster.
bob22 likes this.
BIG Johnson is offline   Reply With Quote
Old 05-22-2017, 12:02 PM   #6
Rewards Points: 1,932
It's not about the amount of water its about a washer being a pumped discharge. Larger pipe tends to make it relax faster. Also IPC is 3 inch once you become a branch drain. More then one fixture. You are trying to minimize the effect of the pressurized discharge on the other fixtures.
406.3 Waste connection. The waste from an automatic clothes washer shall discharge through an air break into a standpipe in accordance with Section 802.4 or into a laundry sink. The trap and fixture drain for an automatic clothes washer standpipe shall be a minimum of 2 inches (51 mm) in diameter. The automatic clothes washer fixture drain shall connect to a branch drain or drainage stack a minimum of 3 inches (76 mm) in diameter. Automatic clothes washers that discharge by gravity shall be permitted to drain to a waste receptor or an approved trench drain.
FIXTURE BRANCH. A drain serving two or more fixtures that discharges to another drain or to a stack.
As 1 fixture 2 inch is the size. Unless it is a stack.
standpipe trap location rtoni Plumbing 7 05-30-2012 03:12 PM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
3" ABS toilet drain - height change - trap arm Rousifier Plumbing 2 02-19-2011 10:41 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
