Haunted Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2015, 06:16 PM   #16
Rewards Points: 109
Should be easy to remove your disposal. It doesn't connect to the sink drain, it is the sink drain. Kill power to it, disconnect electric to the disposal, remove pumning from disposal to the wall. Different types of disposals connect to sink flange in different ways, some have a band with a clip others twist on. Figure out how the disposal motor is hanging from the sink drain flange and disconnect it. After that you need to remove the flange from the sink. Normally there is a large hex nut from the bottom. Get some large channel locks and remove that nut. Push the drain up. Clean it all up and buy a sink drain and P-trap kit and reinstall. Good luck
Olcrazy1 is offline   Reply With Quote
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 03:12 PM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 12:25 PM
