Hammering Noise - Water Recirculator - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-02-2016, 09:00 PM   #1
Rewards Points: 2
Hi -
My husband replaced a cartridge in a shower. He shut off all the water to the house. The cartridge is replaced. Now, when we turn the hot water on, we get a hammering noise. We have turned off the water, drained the system, and turned it back on 12 times and it still exists.
We also have a water recirculator on our hot water heater for instant hot water. The noise appears to come from this.
Any ideas?
Thanks.
ksmndiy is offline   Reply With Quote
Old 05-03-2016, 06:45 AM   #2
Rewards Points: 18
Re: Hammering Noise - Water Recirculator
First, make sure the valves leadong to the shower are fully opened. You may have a valve in the basement to shut off the water to the risers for the second floor (assuming this shower is on the second floor), valves directly behind the shower, and, if it is a Moen shower faucet there may be internal valves inside the faucet. To check for the internal valves, remove the large round coverplate under the handle, and look in the hole for two "screws" that can be turned with a straight blade (not phillips) screwdriver and make sure they are fully open. If that doesn't fix the problem you can buy or make hammer arrestors and solder them on to the hot water pipe. Basically they are simply a 6 inch piece of larger diameter copper pipe with a cap on it. If your existing supply pipe is 1/2" you would use 3/4" pipe for the arrestor. This creates a trapped column of air that will act as a cushion as the water goes on and off. Google "water hammer arrestor" for more information.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Weird shower/tub faucet handle and water flow problem daluu Plumbing 1 01-19-2014 09:08 AM
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 01:53 PM
