Hair Down The Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2015, 07:35 PM   #1
Rewards Points: 1,252
hair down the drain
what are the consequences ? does it degrade ? i have been using a strainer in the bathtub . it has been collecting hair. got me to thinking about all the hair that has already done down.
Fix'n it is online now   Reply With Quote
Old 02-17-2015, 07:41 PM   #2
Rewards Points: 582
if its draining ok what the worry..when it isn't use a small hand snake to open line...hair will clog a drain...
Old 02-17-2015, 07:53 PM   #3
Rewards Points: 6,464
Bleach dissolves hair. Hot water after each application sets for about 15 minutes usually does it.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Fix'n it (02-17-2015)
Old 02-17-2015, 08:40 PM   #4
a p-trap clog is not the issue, thats easy. i am wondering about it building up in the main lines.
Old 02-17-2015, 09:56 PM   #5
Rewards Points: 1,938
Use Bio Clean on your drains. Eats hair grease all that nasty stuff.
http://www.amazon.com/Bio-clean-Drai...words=bioclean
The Following User Says Thank You to Ghostmaker For This Useful Post:
Fix'n it (02-18-2015)
Old 02-18-2015, 06:39 AM   #6
Rewards Points: 582
yep collects at pop-up and p-trap keep those clean and don't worry about your main line because its 3-4 inch so it would take a wolly mamoth yrs to clog it up
The Following User Says Thank You to ben's plumbing For This Useful Post:
Trane XE80 - Drip pan filling up. Drain setup wrong? Please help :) Mognar HVAC 5 06-09-2014 10:52 PM
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
Shower drain in concrete should I replace? Jpatrick Plumbing 4 02-28-2014 06:03 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
