Gurgling Sound From Bathroom Drains - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 01-29-2016, 02:32 PM   #1
Rewards Points: 114
Gurgling sound from bathroom drains
Good afternoon.
In our full bath (sink, toilet, tub/shower combo, and laundry), in the last couple days we have noticed a peculiar occurrence.
When one of us is showering, the toilet makes a gurgling sound. While the wife was in the shower, I looked in the bowl and there were air bubbles coming up from the drain. She commented yesterday that the water level in the toilet seemed lower than normal after she showered.
When the toilet is flushed, a similar gurgling sound can be heard behind the washing machine.
Could this be something as simple as a partial clog down the drain line? Or might it be some kind of suction from a clogged vent?
Has anyone experienced this sort of thing before?
I thank you in advance for any information forthcoming.
Cullen is offline   Reply With Quote
Old 01-29-2016, 02:46 PM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
do you have a septic system or public sewers?
WhatRnsdownhill is offline   Reply With Quote
Old 01-29-2016, 02:48 PM   #3
Rewards Points: 114
Public sewers.
Old 01-29-2016, 02:52 PM   #4
sounds like a partial main line stoppage...
Old 01-29-2016, 02:53 PM   #5
Rewards Points: 3,216
Yes its possible.
Possibly a parcially clogged vent or main line. Check traps for blockage first. Bathrooms are notorious for hair clogs.
jmon is offline   Reply With Quote
Old 01-29-2016, 02:56 PM   #6
Rewards Points: 114
Quick update. Wife just told me that when she was in the shower, the drain in there began to back up, then drained quickly. Hopefully that means it was something in the drain and not the vent.
I'll play with electricity, have done some minor plumbing, a bit of rough carpentry, but prefer to do things that don't take me up too high off the ground.
Old 01-29-2016, 02:57 PM   #7
Rewards Points: 114
Last couple posts came in whilst I was composing my update. Thank you for taking the time to respond to my inquiry, it is appreciated.
The Following User Says Thank You to Cullen For This Useful Post:
jmon (01-29-2016)
Old 01-29-2016, 02:57 PM   #8
Sounds like a partially blocked main line.
The Following User Says Thank You to jmon For This Useful Post:
Cullen (01-29-2016)
Old 01-29-2016, 03:01 PM   #9
Rewards Points: 176
you don't have any of your plumbing draining into a sump/ejector pump, do you?
roobinsteen is offline   Reply With Quote
Old 01-29-2016, 03:07 PM   #10
Rewards Points: 114
No, nothing like that. At least not that I am aware of.
Basements aren't common down here in Texas, and I didn't see anything like that when I spent the day in the crawlspace a piece back.
Old 01-29-2016, 03:28 PM   #11
Rewards Points: 22
You probably have a vent problem. I have the same problem in my basement bath when the toilet is flushed I get gurgle from the sink. I'm gonna try an air admittance vent.
frankrad is offline   Reply With Quote
The Following User Says Thank You to frankrad For This Useful Post:
Cullen (01-29-2016)
Old 01-29-2016, 04:07 PM   #12
vent problems dont just happen, they exist from the beginning ..I doubt a squirrel crawled down the vent pipe and died blocking all the venting....see if you are getting water out the fresh air plate by the house trap. if you can open the house trap, take a look inside..
The Following 2 Users Say Thank You to WhatRnsdownhill For This Useful Post:
Cullen (01-29-2016), Ghostmaker (01-29-2016)
Old 01-29-2016, 04:35 PM   #13
Plumber
TheEplumber's Avatar
Rewards Points: 170
I doubt Texas has house traps.
Your problem sounds like a blockage in the sewer or building drain.
If you don't feel comfortable using a sewer auger, I suggest you hire a locally owned drain cleaner to clean your line.
The Following User Says Thank You to TheEplumber For This Useful Post:
Cullen (01-29-2016)
Old 01-29-2016, 04:41 PM   #14
wow,no house traps... thats gots sux if you drop your ring down the drain...lol
Old 01-29-2016, 04:44 PM   #15
Rewards Points: 114
Usually if that happens, we just get it out of the p trap for the sink. Never had it happen at home, but when I ran a bar years back a customer dropped her ring in the ladies room sink. Got it out for her in about 5 minutes.
Mysterious odor in my bathroom near Vanity / Sink MountainLion Plumbing 10 07-16-2014 10:21 PM
Sound of Coffee Brewing in Water Pipes aidan80 Plumbing 8 02-10-2014 07:42 PM
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 02:04 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 04:22 PM
bathroom exhaust connected to 26' of duct ChrisJJ HVAC 1 01-31-2013 10:50 AM
