Ground Water Problem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2015, 07:21 PM   #16
Rewards Points: 278
Originally Posted by ssikguitar View Post
1 1/2" inch pipe runs 9 ft up and out the foundation into 1 1/2" pvc buried in the ground and it runs 100 ft to a drainage ditch at the north east corner of my lot. Most of the ground around the house is flat and good slope away from the foundation and then it starts to slope away from the house at the northeast corner of my property. Both pumps have check valves on them and they are working. I talked with the guy across from me and he said their is a high water table in this neiborhood. But his pump doesn't run like mine. WTF. What can I do?
Just a thought. If a high water table is the problem, you need to get the the sump pump discharge further away if possible. I'm guessing that the water you are pumping out is going back down into the water table, then back into your pump.
Dan
djlandkpl is offline   Reply With Quote
Old 02-08-2015, 07:24 PM   #17
Rewards Points: 127
More rain and snow might do it. Where is the sump pump discharge going?
jimn01 is offline   Reply With Quote
Old 02-08-2015, 08:54 PM   #18
Rewards Points: 1,930
Are you absolutely sure when the pump discharges the water gets to the drainage ditch?
Ghostmaker is online now   Reply With Quote
Old 02-09-2015, 06:25 AM   #19
Rewards Points: 1,336
You mentioned this in post #5...
Can you have someone come in and dig a trench from the perimeter drain tile to this lower area and pipe in a drain to there. Water wants to flow downhill so if you can move it that way it would be best.
danpik is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Adding ground to electric water heater tadc Electrical 8 03-05-2012 08:14 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
