In Ground Water Line Woes (please Advise) - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
Old 10-02-2017, 05:39 PM   #16
Rewards Points: 6,334
Re: In Ground Water Line Woes (please advise)
It makes me wonder if the back fill procedure states anything about compaction. If it doesn't we can guarantee the contractor will do it the fastest way and just dump dirt back to fill the ditch without compacting in lifts and that wouldn't be much better than no back fill.
It was his choice of pipe so make him do it right.
Old 10-02-2017, 06:03 PM   #17
mike1964's Avatar
Rewards Points: 16
Will wait for additional input but the only way I know to truly make it right is to dig it up (he covered a lot of it), cut off the gasket ends and glue in couplings.
Otherwise... what? cover it up, get more dirt and a whacker-packer? not an option.
I'm thinking, what should have been a fairly simple job has turned into a mess.
mike1964 is offline   Reply With Quote
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
