Ground Level Bathroom Done Wrong - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-10-2016, 12:07 PM   #1
Rewards Points: 2
ground level bathroom done wrong
I have purchased an older (1870's) home where the previous owner has done a hack job of installing a bathroom downstairs. The downstairs is right at ground level with no crawlspace at all. (like if it were a basement where the foundation and floor are all concrete - except in this case the concrete floor is exactly at ground level)
It appears that they broke through the concrete and dug down enough to do the plumbing for the tub drain but there is no concrete (just dirt) underneath the tub. And the house was infested with rats. I've managed to trap and clear out all the rats but I have determined that they have been getting in by tunneling up under this bathtub .. and new rats will come back in until I get this fixed.
It seems obvious to me that the solution is to tear out the bathtub and get this done correctly - but without any crawl space underneath the house, how do you do a concrete floor underneath a bathtub so you still have room to attach the tub to the drain?
Until I have time to rip out and redo everything, I've been tempted to mix up some soupy concrete and pour it in there under the tub (through the access panel) so it will run down in the rat tunnels and at least stop the rats from tunneling in until I have time to redo the whole bathroom. How terrible of an idea is that?
AndyPanda is offline   Reply With Quote
Old 04-10-2016, 06:49 PM   #2
Rewards Points: 3,286
Re: ground level bathroom done wrong
deleted ...................................
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 04-10-2016, 06:53 PM   #3
When you remove the bathtub you can carve away the dirt underneath to pour a new concrete slab section a few inches lower than the existing floor.
It is very common to install a bathroom in a basement where pipes need to be installed under floor level and there is no crawl space.
Pouring soupy concrete down there will probably be a waste of time and effort and concrete. It will make preparing the area for re-installing the tub later much more difficult. If the concrete does not cover the entire surface (hit or miss and luck) then rats will dig new tunnels over to the voids in the concrete.
The Following 3 Users Say Thank You to AllanJ For This Useful Post:
AndyPanda (04-15-2016), Bondo (04-11-2016), joecaption (04-10-2016)
How build a paver pathway above ground level? JClishe Landscaping & Lawn Care 8 06-21-2015 09:15 AM
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 10:58 PM
Resurfacing a ground level deck, needing to drain water gamesinthebasem Building & Construction 0 07-10-2011 06:11 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
