Gross Smell Under Bathroom Vanity Cabinet/sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2014, 11:42 AM   #16
Rewards Points: 3,216
Originally Posted by mxingislife View Post
Should I wrap some electrical tape around the chewed piece of romex before I sprayfoam? I'm almost tempted to cut open the wall in the cabinet to see if I find anything behind the wall, but I don't want to create unnecessary work for myself.
I know. The more you look the more you find that needs fixing.
I agree. That would be a good idea if no bare wires are showing. It doesn't look like it, can't really tell from pic, but if bare wires are showing, have an electrician look at it first. Just a suggestion.
jmon is online now   Reply With Quote
Old 02-05-2014, 11:56 AM   #17
Rewards Points: 225
That semi-sweet/semi-nasty smell sorta sounds like dead mouse/rat ... Maybe whatever chewed that wire crawled up through the hole in your floor planks and croaked under the floor plate of your vanity, probably a 3 inch cavity there........ i would see if you can get the floor plate of the vanity out somehow , if possible without trashing the vanity. Certainly worth a look.
ChantryOntario is offline   Reply With Quote
Old 02-05-2014, 08:23 PM   #18
Doing it myself
Alan's Avatar
Rewards Points: 2,140
Spray foam won't keep them out. Trust me.
Journeyman Plumber
Old 02-05-2014, 08:45 PM   #19
Rewards Points: 199
People use to stuff steel wool in holes like that because mice won't chew through. It's a big hole so maybe some metal flashing and steel wool. I think they make some pest proof spray foam. The regular stuff would be like candy to them. I was kind of thinking you might have a dead mouse under your vanity yesterday but your vanity is so impeccably clean I figured you would run screaming. The carcass will eventually stop smelling on its own. Yuk.
Arlo is offline   Reply With Quote
Old 02-05-2014, 10:04 PM   #20
I removed the toe kick from the vanity and found nothing...this smell seems like a mystery!
Gross smell under bathroom vanity cabinet/sink-image-3167034019.jpg
mxingislife is offline   Reply With Quote
Old 02-06-2014, 07:42 PM   #21
Rewards Points: 1,854
I still go with bad piping or built over indian burial ground... See any ghost lately?
Old 02-06-2014, 09:28 PM   #22
lol no ghosts. Do you suggest that I cut out the drywall in the vanity to take a look at the pipe?
Old 02-07-2014, 06:30 PM   #23
Good nesting for them. They used to use Styrofoam wall panels on the outside of house in the 70's found out that all little critters burrowed tunnels into it. Nice and warm in your walls during winter....
Old 02-07-2014, 06:32 PM   #24
The smell is coming from some where. It might not necessarily be a drain it could be the vent that has no water but does carry sewer gas.
Old 02-08-2014, 07:41 AM   #25
Rewards Points: 1,042
i would not cut a hole. i would take the whole thing out. shouldn't be that hard, mine wasn't.
Fix'n it is offline   Reply With Quote
Old 02-08-2014, 11:32 AM   #26
By "take the whole thing out" do you mean the vanity? And see if the smell goes away?
Old 02-08-2014, 12:08 PM   #27
bbo
id still fix that hole with some metal and id be tempted to try this:
http://greatstuff.dow.com/products/pro/pestblock/
bbo is offline   Reply With Quote
Old 02-08-2014, 12:18 PM   #28
Originally Posted by bbo
id still fix that hole with some metal and id be tempted to try this: http://greatstuff.dow.com/products/pro/pestblock/
Would you use the spray foam in the wall too, or just under the house?
Old 02-08-2014, 02:53 PM   #29
bbo
not really in the wall, but I would cover the plumbing holes and make sure that was foamed too.
Old 02-09-2014, 12:57 AM   #30
Ok, just so we are clear spray foam the plumbing openings under the house but don't spray foam the plumbing openings in the wall right? Just use a split flange to cover the hole in the wall for the drain pipe?
Musty smell in bathroom JoeArbona General DIY Discussions 18 09-30-2012 09:34 AM
sewer smell in bathroom god Plumbing 6 10-16-2011 11:27 AM
bathroom vanity install questions rtoni Building & Construction 3 09-28-2011 02:50 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
