Grey Water Over Hill - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-14-2015, 10:39 AM   #1
Rewards Points: 455
Grey water over hill
I got a place that's gonna sleep 12-15 people for short stays (3-5days then nobody for 3-5 days) with a 1,025 gallon septic tank. It's up in the hills, lowly populated and low enforcement. Some local plumbers are recommending I tap all 3 showers, 2 washing machines, and 3 bath sinks if all possible and send the water out over the hill (in wooded area) small creeks 150ft away to help the septic work better.
Does this sound like a good idea ??
Cletis is offline   Reply With Quote
Old 09-14-2015, 11:02 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,256
Ayuh,.... A grey water dry well would be a Better option, than just dumpin' it in the woods,....
Bondo is online now   Reply With Quote
Old 09-14-2015, 11:26 AM   #3
Rewards Points: 455
ok, thanks for tip. I just am starting to investigate this. i'll google it
Old 09-14-2015, 05:08 PM   #4
Rewards Points: 1,942
I also suggest you contact you local Septic authority and state EPA before one does this. In Ohio grey water waste has it's own plumbing requirements and is regulated by the state. Disposing washer machine waste to the local stream is not an option.
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
