Was Gray Pipe Included - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree22Likes
Old 09-13-2016, 08:37 AM   #1
Rewards Points: 66
Was gray pipe included
Delta model: B510LF SSPPU. ECO
Had plumber here yesterday to install my faucet I bought plus replace old shutoff valves. The plumber has been with this company 2 yrs.
He finished an later I noticed cold water valve leaking. Today the drain is leaking. I called the office. They said possibly its a defective drain and my expense if it was part of what I bought.
I can't tell if this gray pipe is something that would come with a new faucet. Would you know? Sorry, I can't tell from the box or instructions. The box my faucet came in says "popup drain included" but doesnt mention the gray pipe from sink to the white PVC.
For a $75 faucet and $166 plumbing bill I didn't expect complications
Handylassie is offline   Reply With Quote
Old 09-13-2016, 10:22 AM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,854
Re: Was gray pipe included
That came with your faucet.
(Hard to believe its a defective part.... probably something was not tightened.)
de-nagorg likes this.
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Handylassie (09-13-2016)
Old 09-13-2016, 10:27 AM   #3
If the plumbers give you any problem, Tell us exactly where the leaks are and we'll give you arguments as to why it was faulty installation.
Good luck.
Old 09-13-2016, 11:00 AM   #4
hkstroud's Avatar
Rewards Points: 6,694
Agree. It is a 99% chance that this is an installation error.
Even if it is a defective part (and its not) the plumber should have checked for leaks before he left.
No matter what, it is his error for not doing a leak check.
MTN REMODEL LLC and de-nagorg like this.
hkstroud is online now   Reply With Quote
The Following User Says Thank You to hkstroud For This Useful Post:
Old 09-13-2016, 11:24 AM   #5
Rewards Points: 66
I see the leak from drain is where the threads on pipe are, next to sink basin. That dot on left, on the threads, is drop of water.
Old 09-13-2016, 11:26 AM   #6
Rewards Points: 1,932
Your installer failed to pipe dope the black rubber and the threads on your tail piece. That is why you leak.
MTN REMODEL LLC likes this.
Old 09-13-2016, 11:27 AM   #7
Rewards Points: 38
That is a standard Delta drain tailpiece. Not great quality, but I install them often and always without leaks. The "plumber" (or apprentice or worse "tech") screwed up the installation. Not unheard of, even with a real licensed plumber. The "plumber" has to swallow his pride and return to fix his mistakes at no additional charge to you.
SHR Plumber is offline   Reply With Quote
Old 09-13-2016, 11:32 AM   #8
Rewards Points: 38
The leak pointed out by "Ghostmaker" is a typical common leak from when an inexperienced or non-caring installer installs any pop-up assembly. If the installer was a real plumber, it is the result of plain old laziness.
The Following User Says Thank You to SHR Plumber For This Useful Post:
jeffmattero76 (09-13-2016)
Old 09-13-2016, 11:34 AM   #9
I would never tell someone in advance it was his fault. Bad business practice.
Old 09-13-2016, 11:47 AM   #10
Rewards Points: 38
I understand. I am in a mood because I just finished up a repair of bad shower faucet installation that was done 2 weeks ago by one of the most expensive and arrogant plumbing contractors in my area. Like this OP's contractor, they claimed not their fault. I fixed the sloppy work rather quickly but my customer still had to pay again.
That, and this OP's leak looks exactly like a leak I had on my first pop-up install 20+ years ago. I didn't leave until the leak was fixed and it never happened to me again. Been there, seen that. That's why I called out the "plumber". Your attitude will result many less punches thrown...
Old 09-13-2016, 11:55 AM   #11
Rewards Points: 66
Crud!!!
He's here. Said the pipes are cheap. He can replace with chrome.
He said theres a rubber gasket so he diesnt use any glue or tape on threads.
He started working on new shut off valve an it "blew" off. He hadn't turned water meter off an water poured out, filled cabinet and flooded into bedroom carpet. He had me go to his truck an find the post used to turn city water meter off. I couldn't find it so used he old (iffy) meter shut off at the side of the house till he coukd come out to the truck and get his meter took, but by then I climbed in the van an found it.
Old 09-13-2016, 11:56 AM   #12
And.... it may seem that the shop's lead first comment was "might be a defective part that the customer was liable for the repair". NOT, we'll come out and look at it and if it was an installation problem we'll cover it, but if it was a defective part we don't guarantee that.
In general, and not to be skeptical, but it may/kinda sound as a beginning setup to blow over a possibly uninformed HO with a bill. MAYBE NOT....
Old 09-13-2016, 12:00 PM   #13
Rewards Points: 66
Hes so sweet an has little kids so I wont complain but wont use him again.
Meanwhile, should I encourage him to use glue on threads or should I let him install a new chrome pipe.
Old 09-13-2016, 12:01 PM   #14
Rewards Points: 38
I am so sorry you have this incompetent fool working in your house. Remember, they have to pay for the clean-up and replacement of anything destroyed by the water flow which was caused by your "plumber's" actions. That is what his company has insurance for.
And that pop-up is inexpensive but it works. He did not know how to install it. Not knowing how to install a Delta-brand part is inexcusable for a plumber.
Old 09-13-2016, 12:09 PM   #15
ZTMAN's Avatar
Rewards Points: 624
That's his way of wanting to charge your to fix his mistake. There is nothing wrong with the plastic pipe, just the installation.
SHR Plumber likes this.
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
Continuous Current on Water Pipe terps530 Electrical 263 04-11-2015 12:08 AM
Can't drain water from water pipe to outside faucet hansim4 Plumbing 19 02-23-2015 02:07 PM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 12:49 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
