Goulds Submersible Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2017, 12:54 PM   #1
Rewards Points: 14
Is this brand new pump not running or is pumping back into water??? Model 25GS30 Control box Centipro model CB3412MC is putting out 140 volts on yellow lead, 290 volts on red lead, 115 volts on black lead when float switch turns on control panel. When pump first installed it pumped and did not finish filling tanks. This is the voltage readings that we have now on the pump, don't know previous when functioning. Fuses all good. No bubbles in water. Pump is 25ft below water surface in lake. Need it to pump 15k gallons, only pumpled 3k gallons and not pumping now but voltage readings are being sent to pump.
Phil.L is offline   Reply With Quote
Old 05-09-2017, 03:20 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,240
Re: Goulds Submersible Pump
Ayuh,.... Where are ya, 'n what's yer power source,..??
If in the USA, I donno how yer gettin' 290 volts, on a 240 volt system,....
Old 05-09-2017, 05:17 PM   #3
Rewards Points: 898
Did it sit unused for a while in a new heavily chlorinated well?
BIG Johnson is offline   Reply With Quote
Old 05-09-2017, 05:28 PM   #4
Rewards Points: 14
I don't know how i get these readings should only be about 115 . How does the the capacitor start work? Does ot only readvoltage when motor first starts ?
Old 05-09-2017, 05:53 PM   #5
Rewards Points: 238
According to specs the 25GS30 requires a 3 HP motor to run it. No way it should only be about 115. Just out of curiosity why a well pump? Seems like a traditional pump with a long intake hose and weighted intake filter would be easier.
http://documentlibrary.xylemappliedw...B5-25GS-R5.pdf
Fish_Stick is offline   Reply With Quote
Old 05-09-2017, 09:30 PM   #6
Rewards Points: 14
No, it was still in box day before installed
Old 05-09-2017, 09:37 PM   #7
Rewards Points: 14
This is a 3hp submersible, needs to sit 25ft below in lake, pumps up hill 1800 ft, this system has performed fine, simply needed to replace worn out pump in kind. After being hooked up it ran then stopped after two hours. When checking each power leg I have 115 volts on yellow & black output leg from control panel and I have 249 volts on red leg. Can't figure out why its stopped working altogether now???
Old 05-09-2017, 09:41 PM   #8
Rewards Points: 14
Old 05-10-2017, 01:09 PM   #9
Rewards Points: 238
Sounds like you need to pull it and check it out before anything else can happen. Something could have clogged it or a connection could be loose. Take it into shallow water and test it there without being connected to the pipe setup and see what it does there.
What's the total head on the setup?
Tags
control panels , pump , submersible , submersible well pump , water pump
submersible well pump . first start. ryanh Plumbing 13 05-09-2017 03:40 PM
wire size for 1 hp submersible water well pump? vettegc Electrical 7 10-10-2014 07:59 AM
cant figure how to remove diffuser on Goulds pump noquacks General DIY Discussions 10 09-29-2014 03:52 PM
submersible pump or pressure gauge Henry M Hobson Plumbing 0 01-22-2013 04:59 PM
submersible well pump switch? jerryinmich57 Plumbing 7 03-13-2011 03:27 PM
