Goulds Balanced Flow Constant Pressure Pump - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-20-2016, 03:38 PM   #1
Rewards Points: 8
Goulds Balanced flow constant pressure pump
I need to replace my well pump and was considering getting a Goulds balanced flow constant pressure 3hp 18gpm pump. Just wondering if anyone has used this pump or have any recommendations on a different constant pressure pump. Thanks
rt520 is offline   Reply With Quote
Old 05-25-2016, 12:49 PM   #2
SHEPLMBR's Avatar
Rewards Points: 178
Re: Goulds Balanced flow constant pressure pump
Need to make sure it is sized properly. 3hp is pretty big. If you don't have the recovery rate you will be in trouble. Bigger is not always better.
SHEPLMBR is offline   Reply With Quote
Old 05-27-2016, 09:30 AM   #3
Rewards Points: 8
I have a 3hp pump already. Well is 330 feet with a long pull to the house up a hill.
Well pump not gaining pressure Offalot Plumbing 5 10-23-2012 02:30 PM
Boost Pump for Improved Water Pressure ralphfravel Plumbing 2 08-04-2011 07:33 AM
Craftsman Pressure Washer 580.761800 pump question SteveLake Tools 0 06-22-2011 09:51 PM
New tank new pump, no pressure?? Toyz Plumbing 2 07-26-2008 07:38 AM
Pool Motor Wiring Assistance tazmajazz Electrical 18 05-16-2008 10:42 PM
